R56 Bleeding MINI ...
Old May 19, 2008 | 05:46 AM
morbius's Avatar
morbius
Dr. Morbius
Bleeding MINI ...
Tip: If your mini has a bleeding/crying problem with cosmoline, I have a very easy to clean the mess up with no residing stains. Windex glass cleaner does the trick with no harmful side effects.
Found my mini the other day after long runs in 105 degree weather was bleeding cosmoline all of the place. Had the windex bottle nearby after cleaning the windows and gave it a try. Clean the stuff right off the all the black trim in seconds with residing trailing marks. The black trim looks new again. Hit a couple body spots also with no issues.
Took minutes For once, something easy on a MINI
Old May 19, 2008 | 05:52 AM
ScottRiqui's Avatar
ScottRiqui
The fact that you got to the streaks so quickly probably has as much to do with it as the cleaner you chose. Glad to hear the protectance came off so easily!
eliseo1981
Jan 28, 2021 02:45 PM
phrza81
Oct 10, 2015 11:37 PM
Lt. Dan
Aug 10, 2015 12:46 PM
Gipper
Aug 8, 2015 05:39 AM
