To confirm: R56 w/rubber valve stem means no direct TPMS?
Old May 15, 2008 | 11:55 AM
mf44's Avatar
mf44
Hi
About to buy a set of wheels that cannot take the direct TPMS system. I just wanted to make sure that if my R56 has rubber (not metal) valve stems, that it indeed has the older style system on the R53. So that I will not need TPMS sensors mounted.
Thanks for the help guys!
Old May 15, 2008 | 12:09 PM
kazlot's Avatar
kazlot
To confirm: R56 w/ rubber valve stem means no direct TPMS?
The short answers is yes. Buy the wheels!
Hope this helps...
Originally Posted by mf44
Hi
Old May 15, 2008 | 12:12 PM
lttletimmy's Avatar
lttletimmy
correct, if you have rubber valve stems then it senses changes in tire pressure via the rotation speed of the wheel, not via a sensor mounted inside the wheel. So yes, you're good
Old May 15, 2008 | 12:46 PM
mf44's Avatar
mf44
Thanks for the answer guys! Appreciate it.
Old May 15, 2008 | 02:12 PM
ijcwmc40's Avatar
ijcwmc40
Can anyone say if the R53 sensor will trip if there was a different size tire on front vs rear. e.g. 2xF=215/45/17; 2xR=205/45/17
Old May 15, 2008 | 07:49 PM
lttletimmy's Avatar
lttletimmy
I'm not certain but I think it measures the difference from left to right, not front to back. At any rate, if it trips, you can reset it. Why are you running different sized tires?
Old May 16, 2008 | 05:21 AM
ijcwmc40's Avatar
ijcwmc40
Since my last set, I decided to follow MINI's recomendation of not rotating tires, which IMO they perform much better. But of course the front tires wear faster than the rear and Kumho is no longer offering 205/45-17 in the Ecsta SPT.
David.R53
Sep 1, 2015 06:49 PM
SunnySideUp
11
Aug 26, 2015 06:42 AM
Lex2008
Aug 16, 2015 08:33 PM
Emnotek
Aug 13, 2015 05:47 PM
