Navigation & Audio SIRIUS Stiletto mounts
Anyone have any good ideas about mounting a Sirius Stiletto in a 2008 MC? I’ve got the wiring wired (so to speak) and the antenna hooked up, but I’m having trouble with ideas on a good place to stick it without wires running all over the place. I can run power from behind the cig lighter (although I’m gonna have to stow the male/female cig lighter sockets somewhere), and I think I can get the antenna wire there, but I’m still forced to run a cable to the aux port.
I suppose there must be a way in behind the whole radio facade, but even then I’d probably have problems exiting the wires from there, and I still don’t see a good place for it.
So it seems like maybe the passenger cupholder. But those expanding cupholder tower mounts are too tall, and block the passenger window switch.
Any ideas?
Rob
Any ideas?
Rob
I will post how i did mine with the kuda mount and the modifications i did, its still not perfect but i have been going through different variations. What i have now will be the final work and then i will just get replacement screws that are flat on top.
Pics this afternoon.
I put my xm radio in the cubby in front of the shifter. I got the hardwire dc adapter for it and put it under the lower dash cover. The dash wires were run under the plastic trim. I cut a piece of wood painted it black and put some velcro on it and the receiver. It's on a dock so I can remove it and use it in a boom box kind of thing in the house. The view isn't perfect, but if you really want to see the artist you can look down there. I like it because it is out of the way.
https://www.northamericanmotoring.co...0&ppuser=35711
Pictures are in my gallery
I did alot of mods to the mount. I was not happy with the way the kuda mounts. It uses 2 tabs on the center console side that slip in the gap between the heat/cool dial and the right side of the cd player. This makes the heat/cool dial stick.
So i moved the mount as high as it would go and put in 2 screws to secure it in place, there was a slight amount of movement from left to right so i took a the mount down and bent the screw tab in slightly to hold the mount in place better.
I cut a hole in the base of the mount to allow the cables to feed. I need to find 2 new screws that have much flatter heads and will not cause a gap.
It did before i bent the screw tab back, but once i did this it stays about 2 mm out of the way.
Its at a perfect angle to see even in the sun and the buttons are easy to get too. The cd is the only thing thats in the way but because i do not use the tabs, the mount moves just enough to allow the cd in.
Maybe PROCLIPS
I have an R56 MCSa and I hated the idea of shelling out money for the MINI NAV and being installed on the left side of the driver side.
I was at the Carlisle Show and RAB from DC Metro Mini suggested PROCLIPS because they do two things:
1. Take the model of your Navigation System, Satellite Radio, or any handheld device and have a "holder" for it and it attaches to the;
2. Take the model for your car and a make "mount" for it.
Attach the two together to make the perfect attachment on your dash without the suction cups on your windows.
<www.proclipsusa.com>
Navigation & Audio HK Replacement With New Components
Filmy
15
Jun 6, 2023 06:27 AM
elverado
Jan 18, 2022 02:51 AM
GregoryK
Dec 14, 2015 01:34 PM
Sep 4, 2015 02:34 PM
