R50/53 Weak rear defroster?
Old May 12, 2008 | 06:33 AM
Xymox's Avatar
Xymox
It was drizzling this morning on my commute. Not enough to warrant the rear wiper, so I switched on the rear defroster. On the cars I've owned in the past, this is usually enough to evaporate most of the water collecting on the rear window. However, I noticed it didn't do much of anything.
After arriving to work I pulled the fuses from inside the car and checked F16 and the fuse was fine. Is the MINI's rear defroster just that weak?
Old May 12, 2008 | 06:39 AM
hegira's Avatar
hegira
Hi,
I drive on '02 MCS, and my de-mister works pretty good. The rear wind-shield begins clearing within 10-15 seconds or so, and within 5 minutes the window is clear.
I know that aggresive cleaning on the inside of the glass can break the fine wires that make up the de-froster grid.
Old May 12, 2008 | 07:01 AM
MiniTron's Avatar
MiniTron
I have also had situations where I turned on the rear defroster to clear a mist from the rear window on to find that the road grime on the class was just as hard to see through when the glass was dry.
sevin
May 2, 2026 06:11 AM
NYXF56JCW
Nov 17, 2024 05:06 AM
maniacalmorgan
38
Sep 29, 2015 04:56 AM
tacticalbacon02
Aug 22, 2015 06:05 PM
