Any reason to switch wheels?
Old May 9, 2008 | 08:20 AM
UnsanePyro's Avatar
UnsanePyro
I still have the runflats, which, I want to get rid of, probably in the spring. Is there any reason to switch from the stock wheels that are on my mini now, to a different size? I'm have the S-Winders, which from what I have read are about 17-17.5 pounds each.
I feel like there isn't, based on weight/size, but what about tire size, how wide can I run on a 16 at stock height or possibly a 1" drop?
Old May 9, 2008 | 08:27 AM
Bhatch's Avatar
Bhatch
no reason other then looks. Unless you neeed a wider rim to mount wider tires on.
like a 235 need a 8" wheel and the stock 17" are 7"
Old May 9, 2008 | 08:33 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
The S winder rims are functional. Stock tire is 195/55-16
Optional tire sizes for 16x6.5" rim is large.
Common size for street use would be
205/50-16 which is a little less than stock tire diameter at 24.1"
205/55-16 which is a little taller at 24.9"
If you are lowering 1" then it's safer to go with 205/50-16.
Old May 9, 2008 | 09:48 AM
Bor's Avatar
Bor
I went from the S-Winders with the runflats to 17" Rotas with low-profile tires - for better handling (which I'm happy with now, even stopped considering switching to the JSW suspension from my SS) and for the looks - I de-chromed my car, the wheels were the last thing, check my gallery
wkp1219
Nov 13, 2015 07:52 AM
eatsleepautox
Oct 30, 2015 06:46 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
nomar116
Aug 14, 2015 04:54 PM
