Suspension Excessive Camber
Old May 8, 2008 | 10:06 AM
minilites's Avatar
minilites
Excessive Camber
Morning all,to all that have lowered your cars and wound up with excessive
camber in the rear,did the use of lower arms correct the problem ? i just
lowered my car with H&R green springs and wound up with left side with
-2.4 and right side with -3.5 all constructive comments welcome.
I just ordered megan adjustable arms.
Old May 8, 2008 | 10:23 AM
quikmni's Avatar
quikmni
I used H-Sport adjustable lower control arms to correct the neg. camber on my lowered (with H&R springs) 2003 MCS. I went to -1 degree.
Old May 8, 2008 | 12:51 PM
MadHatter's Avatar
MadHatter
ditto to quickmni - except -1.8
Old May 8, 2008 | 12:59 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Wow....-3.5 from springs? It's usually around 1-2 degrees of negative camber....3.5 seems to suggest that there is something else wrong. My H&R green springs left me with -1.2 degrees in the rear.
Any chance of bent parts back there or something?
Old May 8, 2008 | 11:13 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Yup. It happens.
My 2003 MCS with stock shocks and H-sport springs.
Once installed the rear camber was -2.4 both sides and ride quality was very poor. I drove over a rough road and everything in the car was shaking and rattling.
I had adjustable lower rear control arms as well set to stock length and used them to dial in -0.7 degrees both sides in the rear that worked very well. Later I changed the rear camber to -1.6 and more recently -1.2.
Front camber doesn't change with lowering springs.
Keet
Suspension
Aug 30, 2016 03:46 PM
schr5530
Oct 5, 2015 08:28 AM
M7Speed
Oct 1, 2015 07:05 AM
fkrowland
Sep 30, 2015 10:30 AM
Sep 21, 2015 09:04 AM
