MINI Motoring Club of the Carolinas (M2C2) The MINI Motoring Club of the Carolinas forum. Visit our club site at www.m2c2.org
PSI
Old May 8, 2008 | 09:49 AM
comet5o4's Avatar
comet5o4
PSI
Ok, so in the past I've always run my car tires at 35 psi. I was looking at the tired that I have on my MINI and it said 44 psi... What do you all run your tires at?
Old May 8, 2008 | 10:23 AM
glnr13's Avatar
glnr13
38 cold on the dailies
Old May 8, 2008 | 10:25 AM
ScottRiqui's Avatar
ScottRiqui
If there's a pressure molded into the tire's sidewall, that's probably a maximum pressure. I usually use 36 PSIG cold on my 205/45-17 Falkens.
Old May 8, 2008 | 08:33 PM
MidnightDave's Avatar
MidnightDave
Normal driving 38 cold all around, twisties 42 cold, track some combo of 42 to 46 depending upon what Joe's pit crew tells me ;-). They'll go up 2-4lbs hot.
Use your own best judgement...
Old May 9, 2008 | 07:17 PM
Grassroots Garage's Avatar
Grassroots Garage
I go a little lower on the track because of the increased heat, but alway run and set my customers cars to 36. I think anywhere from 34-38 is good depending on what kind of ride you want.
--Dan
Old May 9, 2008 | 07:18 PM
Grassroots Garage
I go a little lower on the track because of the increased heat, but always run and set my customers cars to 36. I think anywhere from 34-38 is good depending on what kind of ride you want.
--Dan
honderpilot
Oct 11, 2015 06:35 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
silence2-38554
Sep 28, 2015 12:19 PM
EVMini
Sep 28, 2015 10:20 AM
potterstein
Sep 13, 2015 09:57 PM
