Will 215/45-17's fit my R50?
Old May 8, 2008 | 09:43 AM
05Greenie's Avatar
05Greenie
I have been informed on this site that tire height cannot exceed 24.3", yet I have read threads of other owners with a 215/45-17 tires.
I an interested in General Exclaim UHp tires 215/45-17 and the spec sheet from TireRack states a tire height of 24.6" will these fit my R50????
I currently have Yoko Prada spec-2's 205/45-17 that are worn to the bone.
Old May 8, 2008 | 10:00 AM
PGT's Avatar
PGT
yes (but this is the second time you've asked and second time I've answered the same )
Old May 8, 2008 | 10:17 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Why would tire diameter greater than stock 24.3" be a limit on your tire size selection when using any MINI with stock suspension? You have plenty of clearance above each tire. No problem.
Owners of any MINI using stock suspension surely can use 215/45-17 but the dealership recommends using stock 205/45-17 tires which came with the car and were designed that way by MINI. Costco as well recommends using tires of the same size as OEM when possible.
Your R50 and all other MINIs using stock suspension will be fine with 17" rims usually 17x7 with +48 mm offset or close to it and with General Exclaim UHP 215/45-17 $75 each, $83 each if you get 205/45-17!
215/45-17 is slightly taller than stock so you do get a little speedo and odometer error. It's minor for street driving. It's about 10 mm or 1.6% taller than stock. When speedometer reads 60mph (96.6km/h) actual speed will be 61mph (98.2km/h): about 1.7% faster.
Old May 8, 2008 | 10:49 AM
05Greenie's Avatar
05Greenie
Thanks to everyone for all the information. Sorry for the redundent questions regarding tire fitment. I wanted to be sure when ordering tires online that they will fit and everyone here has been very helpful.
I ordered the 215/45-17 General Exclaim tires from tirerack and they will be on my buggy by next tuesday.
Thanks again for all the feedback.
Regards,
Mark
Old May 8, 2008 | 10:05 PM
minihune's Avatar
minihune
Regards,
Mark
Once you get them on see how they fit for you and give us a report about how they work for you.
Cheers.
Old May 13, 2008 | 11:25 AM
05Greenie's Avatar
05Greenie
Well, I got the General Exclaim tires (215/45-17) mounted and balanced at a shop recommended by Tire Rack. Martin Tire on Park Ave Worcester, MA is AWESOME...~ 3 minutes after arriving and talking with the GM I felt like I was at NASCAR...3-4 guys were outside had my car jacked up with all 4 sneakers pulled off lickity split....man that was fast. The owner insisted on observing the process every step of the way from demounting to mounting and balancing..new equipment for mult sized rims and tires as well as a nice laser balancer. Each tire was $17.50 with new valve stems and caps as with each tire balance. I was itchin' to get ti on the highway and when I did...Oh man..I was crusing along and I looked at the speedo and I'm doing 90...If I had a 6 sped I would be getting a lot more speeding tickets.
Tire run and feel awesome...so far I'm happy.
Thanks to everyone who helped me out with the tire purchase....
Aug 19, 2015 12:51 PM
Aug 19, 2015 10:17 AM
Aug 19, 2015 08:57 AM
Aug 12, 2015 01:24 PM
Accessory Products
Aug 11, 2015 12:59 PM
