18 x 8 OZ Ultralegerra offset
Old May 7, 2008 | 07:38 AM
thugbug99's Avatar
thugbug99
hey guys...noob question...tried searching for this particular size before posting...
little guy is due to arrive in a few weeks, trying to figure out what offset to go with the above configuration or should i go 7.5 to play it safe? i dont want the wheels to stick out past the fenders, possibly may lower the car at a later time and will most likely add a BBK...if i go with 18 x 8, tire size would be 225/40/18...
Feedback is much appreciated, pics are even better
Old May 7, 2008 | 03:42 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
For 18" O.Z. Ultraleggera I only see 18x7 +42 offset and in Black painted finish, otherwise you are limited to 17x7" +37 offset
215/35-18
or
215/40-18
are better sizes
225/40-18 is too tall at 25.1" tire diameter and won't fit if you lower your car even a little.
18x7 with +42 offset should work ok with 215/40-18 tires.
Old May 8, 2008 | 08:13 AM
ben@tirerack's Avatar
ben@tirerack
Minihune is correct. The only 18" Ultraleggera that currently comes in in 4x100 is in fact the 18x7.
Old May 8, 2008 | 08:17 AM
thugbug99's Avatar
thugbug99
Well that helps...Thanks for the reply
bahman
Aug 6, 2016 07:19 AM
Chibi2
May 19, 2016 03:46 PM
Amberleigh MacIntyre
R55 :: Clubman Talk (2008+)
Nov 11, 2015 11:59 AM
vbmike
Oct 15, 2015 04:32 AM
