Can you buy TPMS?
Old May 3, 2008 | 05:09 PM
cutters68's Avatar
cutters68
Can you buy TPMS?
I have a second set of wheels for my 08 MCS. I could swap out the sensors from my crown spoke OEM wheels but would like to get a set for the new rims with non run-flats so that my TPMS light will not be on all the time. If they are available, where? and how expensive? Or should I just live with the TPMS light on. Thanks!
Old May 3, 2008 | 05:16 PM
bad venge's Avatar
bad venge
I see them on ebay , but at $180 each I'd live with the light ...
Old May 3, 2008 | 05:17 PM
()()=='s Avatar
I just Googled tpms. There were several hits including this.
http://tpmssource.com/tpmssensors.as...FSQwiQodTWZjWg
I've also seen them on the site of one of the vendors that advertises here (but I couldn't find it when I looked quickly).
Have you checked with your wheel dealer?
Old May 3, 2008 | 06:59 PM
STLMINI's Avatar
STLMINI
Your MINI dealer sells them. They are around $200 for 4.
Old May 3, 2008 | 07:28 PM
MattH25's Avatar
MattH25
Forget all those places. PM or call Alex at Tirerack (contact info should be in one of the stickies). $184 for all 4 sensors & all 4 valve stems. Figure about $10 shipping and you have everything you need for less then $200; not to mention ridiculously fast shipping
Old May 3, 2008 | 07:41 PM
rippymcs's Avatar
rippymcs
Make sure you ask for adapters as well (for your aftermarket wheels).
Old May 3, 2008 | 07:56 PM
cutters68's Avatar
cutters68
The wheels are MINI OEM R99's. I wouldn't need and adapter for them would I?
Old May 4, 2008 | 10:46 PM
kopov's Avatar
kopov
I just installed the JCW R105 rims and tires on my 07 MCS and used my TPMS from my 17" Crown spokes. I resetted the TPM and everything is fine. You don't need to buy another set of them unless you are using both sets of wheels.
Waszak
Oct 21, 2017 05:55 PM
PSU 98
Sep 11, 2015 11:20 AM
renchjeep
Sep 6, 2015 01:54 PM
