R56 royal purple oils
i use regular royal purple. i see no reason to go to anything else. my car dyno'd 13 whp when i switched from castrol to royal purple. the xrp- is extreme performance racing, and its recommended for off-road, racing or highly modified engines. i dont think its necessary in all honesty
I don't see any ACEA ratings on their web site so I was trying to get an idea how the 5W-30 compared to an ACEA A3 oil. It looks like 5W-30 SL has a somewhat lower viscosity at temp than an A3 oil.
Here is what I found for Royal Purple 5W-30 SL:
cSt Viscosity @ 100C: 10.6
SUS Viscosity @ 210F: 59
Here is what the MINI branded 5W-30 measured at after 5,200 miles:
cSt Viscosity @ 100C: 11.26
SUS Viscosity @ 210F: 63.7
Does it matter? I have no idea.
I can't tell you what is better for the MINI engine, but it seems to have been designed for A3 oils. So, my guess would be that the RP SL is a little thinner than it was designed for. Whether that makes any difference in wear or cooling, I don't know.
i need to put up a sig. at this point i dont have a mini. i currently have mazdaspeed 6. my next car looks to be a mini cooper s if not a jcw. i like to do my hw prior to buying a car.
please tell me if I am wrong but from what I understand, lower viscosity means less protection, but also less fraction on the moving parts and therefore the engine can produce more power / higher mpg. So if you are driving gently and not pushing to the limit, it wouldnt hurt to use a lower viscosity oil
Can't argue, Robin, but why is it the MINI owners' manual only requires 5W30 or 40 and SM? Nothing about ACEA or BMW LLxxxx standards.
Royal Purple 5W40 has an SM rating. I'm going to try it at 5k, which is coming up soon. Of course, I have to order it because all the shops around here carry only the 5W30 RP, which is SL, as you point out.
If RP doesn't live up to its promises, or if I read something else that argues against it, I'll change oil to the fully synthetic Castrol or Mobile 1. The Castrol says it's an A3 oil as well as SM. Don't remember Mobile 1's claims.
My speculation is that the marketing dept. department had something to do with the switching to a USA standard. ACEA A3 oils are a bit hard to find in the USA. The average user would probably see it as a serious negative if they had to looking for an obscure European oil. People who expect to be able to buy a qt. of oil at a gas station would not be pleased. I suspect it would generate a lot of negative threads here as well.
I wish I knew more about what range of viscosities @ 100C were good for the Prince engine.
[FONT=TimesNewRomanPSMT]
I note from the Mobil web site that Mobil 1 comes in regular and extended performance versions. Only the extended performance type is guaranteed to last 15k miles. It contains 50% more of some special additives than the regular. So, apparently it isn't enough to get just any ol' Mobil 1.
[/FONT]
molala
Oct 2, 2015 01:53 PM
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
Sep 10, 2015 12:34 PM
Sep 2, 2015 09:05 AM
