Drivetrain Getrag gearbox from an S in a cooper
Hmmmm,
(also posted on mini2.com)
Just thinking.....what if i were to get a getrag gearbox from say a crashed cooper S, and want to fit it too my cooper - are there any major pros's or cons, pitfalls or anything else that i should be thinking about?
Ive an indiction kit, so the airbox shouldn't present a problem, but will the battery position? It has been mentioned that i might have to move it to the back, a la cooper S?
any thoughts?
Gerry
any thoughts?
Gerry
I'm glad I'm not the only one thinking about this! My understanding is that its a fairly straightforward fit although the clutch will also be replaced. I've been looking for one from a wrecked MCS for awhile and I seem to be missing the connection. Want to enlighten me to the location of one :smile:
I have no knowledge if it is possible or not, but off the top of my head, issues that I think could come up would be;
-mounts / subframe being different
-gear ratios not proper / optimal for the power band of the MC
-shifter linkage
-any electronic sensors / wiring / programing that reads the trans
-MC's half shafts fitting properly
-clutch assembly and flywheel difference
-fitment of the misc items in the engine compartment around the trans
Murphy's law will make sure it wont be easy.
Wastik
-shifter linkage
Wastik
You can do it... new, the Getrag costs about $3500 I thought, but minimania.com is selling it for over $5200.
..."for your brojken one or ideal for an upgrade from your Cooper 5 speed..."
_________________
[img]albums/album25/ama.gif[/img]VinceAndJessica.com
Alta pulley, Stebro exhaust, Pipercross intake, Progress rear anti-sway bar.
_________________
Dont forget, the gearing is different, the differnetial gear is different, the MC is much lower than the MCS, so your speedo will be wrong, unless you find a way to change the speedo gear....
It would make it more interesting how it falls out though, because if it works, then you could use the cooper differntial in a MCS and then have a good dragster..
>>_________________
A breaker i called said that around £300 for a gear box is the mark - so $500 ish?
>>_________________
Aug 12, 2015 01:24 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
