Drivetrain Pinging
Old Apr 21, 2008 | 11:37 AM
jtack's Avatar
jtack
Pinging
Yesterday I had a strange thing happen. I boosted to about 10psi from a 30mph roll and heard my car pinging (pre detonation) I quickly go off the gas. I was not sure if thats really what it was so I tried again and same thing...sounded like a bunch of marbels in a can. I quickly got off the gas. I drove home and picked up my brother...i wanted him to hear the noice to confirm what i was hearing. For whatever reason I could not get it to ping again? 91 Octane Shell, 83 Degrees, flat ground. I was about 1/2 through my tank of gas and it has been running very strong. This morning I drove it and no problems at all? Why would it ping for a few rolling runs and then not again?
Thanks!
Old Apr 21, 2008 | 12:24 PM
DenisP.ru's Avatar
DenisP.ru
Thanks!
maybe its a bad gas - mayby its a bad kharma try to use hi-octane gas one time, and try to drive when U have less than 1/4 of tank - if the problem goes again - look (and photo) your plugs - maybe they dead
in russia we have so much problems with bad gas
Old Apr 21, 2008 | 12:46 PM
ninjlao's Avatar
ninjlao
Ninja Mini
In states the highest octane rating is 91. Unless of course you find those remote stations that sell racing gas for $6 a gallion >_<
Old Apr 21, 2008 | 03:49 PM
verveAbsolut's Avatar
verveAbsolut
Umm...I fill up with 93 every week.
Speak for yourself on the West Coast. Whole Southeast is 93.
- Matt
Old Apr 21, 2008 | 04:25 PM
that7guy's Avatar
that7guy
Uh, I guess ive been filling up with phantom 93 for years !
My guess is with bad gas. You should really switch to a higher octane. Its worth the $
Old Apr 21, 2008 | 04:54 PM
uRabbit's Avatar
uRabbit
In the state of Idaho, we run everything from 89 to 93, and there's one station with racing fuel. I run 93 at all times.
Old Apr 21, 2008 | 05:00 PM
jhiggs26's Avatar
jhiggs26
It could be carbon build up in your combustion chamber creating hot spots that are firing the charge prior to spark. Pop out your plugs and take a peak at your piston tops. A few guys here have used 'Sea Foam' to de-coke their combustion chambers and piston tops. Good luck!
Jeremy
Old Apr 21, 2008 | 05:01 PM
that7guy's Avatar
that7guy
Jeremy
Sea Foam FTW! Worked wonders on my Miata. I put it in the oil, gas tank, and through the Throttle Body.
Old Apr 21, 2008 | 05:13 PM
moodylewdd's Avatar
moodylewdd
Yep, 93 is the way to go if you can get it. Stinker sells it in SE Idaho...good stuff!
Old Apr 21, 2008 | 05:16 PM
uRabbit's Avatar
uRabbit
Stinker ftw. You an Idahoan?
Old Apr 21, 2008 | 05:21 PM
jgooch74's Avatar
jgooch74
in chicago i buy 93 octane.
Old Apr 23, 2008 | 01:01 PM
1moremph's Avatar
1moremph
bad gas or dead plugs. maybe plug wires could be shot?
Old Apr 23, 2008 | 01:58 PM
moodylewdd's Avatar
moodylewdd
Yep...Blackfoot, soon to be Moscow as I head there for grad school! Not really that many MINIs around here, I imagine there is more going on in Boise right?
Old Apr 23, 2008 | 03:08 PM
ninjlao's Avatar
ninjlao
Ninja Mini
My mistake, the west is all 91. So depending on where he is located he may not have access to gas higher than 91 octane.
Old Apr 23, 2008 | 03:39 PM
second to none's Avatar
second to none
Thats funny about the pinging, because when my car was stock i for the most part (except track events) ran 87 octane, 10psi, not a single problem. even now with gas over $4. I am considering going back to 87 because I never use boost on the street (responsible driver)
Old Apr 23, 2008 | 03:55 PM
herbie hind's Avatar
herbie hind
tjack do a search on ticking sound . a "card in the spokes " sound can be heard on many members' cars due to it has been found, the pre 05 harmonic damper . if your symptoms are the same i suggest you contact randy webb for a used 05 damper . luck .
Paul!
Electrical
16
Feb 18, 2025 06:29 AM
Mini ni
Sep 24, 2015 05:42 AM
honderpilot
Suspension
Sep 11, 2015 04:05 PM
jaridp
Test Forum
Jul 8, 2008 07:01 AM
Chief_Charlie
Aug 29, 2004 07:52 AM
