Suspension Lowering and tire clearance
Old Apr 13, 2008 | 04:26 PM
Minibiker11's Avatar
Minibiker11
I'm new so bare with me. I'm in an 2005 S model early year production. I've just put 7.5" wide 40mm offset 17" wheels on the car with TOYO T1R non run flat tires.
My concern is will I rub if I lower a small amount, and is it possible with coil overs such as Megans or SPAX to only lower in the rear a small 1/2". Wouldn't mind 3/4" or 1" in front if the wheel and tires allow. Also, any other options would be welcome also. Thanks for any advice I can get
Old Apr 13, 2008 | 05:02 PM
S-Driver's Avatar
S-Driver
You should be fine with those numbers.....what size tire you running? 205 or 215 shouldn't present a problem. I run a 215/40 with a 17 x 7.5 with a 45mm offset and before I installed BC coilovers I had no rubbing even with Eibach lowering springs. BC's went on and I had to use a 5mm spacer up because of the strut tower interfering with the tire but no issues in the rears...
And you can set the ride height any way you desire with coilovers.
Old Apr 13, 2008 | 05:19 PM
Minibiker11
Lowering and Tire clearance
So I should be OK then?? The Coil overs I've seen id ads always seem to say in example a minimum of 1" to a max of 1.9" I just thought that the min was exactly that, no setting between 0 and 1"??
Old Apr 13, 2008 | 05:21 PM
Minibiker11
Oh yea, I'm on 215/45 17 tires, on 7.5 wide rims 40mm offset they are 17's also
Old Apr 13, 2008 | 05:22 PM
Guest's Avatar
Guest
1 inch is only slightly more than the JCW suspension, you shouldn't have issues with rubbing.
I ran 215/45/R17 profile tires with no rubbing, lowered on H-Sport (About 1.3 drop).
Old Apr 13, 2008 | 05:39 PM
Minibiker11
Old Apr 13, 2008 | 05:41 PM
Minibiker11
thanks
Old Apr 13, 2008 | 06:32 PM
Guest's Avatar
Guest
The issue is that the shock is actually shorter by one inch, not that the settings start at 1 inch.
You should be fine though .
Old Apr 13, 2008 | 06:43 PM
Minibiker11
cool, thanks for help
loop4re7
Oct 5, 2015 09:53 PM
barnoun
Aug 27, 2015 10:08 AM
Emnotek
Aug 13, 2015 05:47 PM
minipopkart
Aug 13, 2015 05:22 AM
