R50/53 Gearbox oil?
Old Apr 10, 2008 | 08:07 PM
SCVMINI's Avatar
SCVMINI
Gearbox oil?
I am looking for some info on my 05 Cooper S 6 spd trans. What kind and how much gear oil does it use? Is it easy or necessary to change it?
Old Apr 10, 2008 | 08:24 PM
hemiheaded18's Avatar
hemiheaded18
I believe the R53 trans specs the same fluid as the Midlands which goes like this: from the factory they are filled for life. This is BS to me and a lot of people. On the non-S trans, there are 2 metal plugs that are removed for draining and refilling the trans. I used RedLine MTL (manual trans lubricant) which costs maybe $6-7 a quart. It's good stuff. I bought 3 quarts because on the non-S trans, the fill capacity is like 2.1 quarts. But, this is all R50 facts. Double check or if possible, someone correct me on anything here.
Old Apr 10, 2008 | 08:29 PM
COR BLMY's Avatar
COR BLMY
ditto for the S
same oil
same drain fill and check method
Old Apr 10, 2008 | 09:30 PM
k-huevo's Avatar
k-huevo
http://www.lonestarminiclub.com/foru...read.php?t=474 for a how-to
Old Apr 11, 2008 | 02:34 AM
hegira's Avatar
hegira
About 2 weeks ago, I changed the gear-box oil on my '02 MCS using Redline MTL. It took about a half-hour. I also changed the oil/filter, using Royal Purple (great stuff!).
It definitely improved the smoothiosity of the shifting.
The next step is to install a short-throw shift kit. I'm not sure yet which one, though.
Old Apr 11, 2008 | 06:36 AM
resmini's Avatar
resmini
I changed my Midland fluid to Amzoil and it shifts smoother. I'm also hoping it will reduce the probability of my Midland crapping out.
Royal Purple in the engine feels like a couple of extra HP....maybe.
Old Apr 11, 2008 | 02:54 PM
hegira's Avatar
hegira
"Royal Purple in the engine feels like a couple of extra HP....maybe"
Damn straight!
The only place it really matters is the place between my ears....
Old Apr 11, 2008 | 06:57 PM
SCVMINI's Avatar
SCVMINI
Thanks for the info everyone
Old Apr 11, 2008 | 07:44 PM
indygomini's Avatar
indygomini
Red Line MTL in my '03 S- happy with it so far.
Can't answer as to the difference it made vs. before switching from the factory fill though, as I also installed a B&M shifter during the same foray under the car.
(off-topic, but also running Red Line 5W-30 in the engine)
Old Apr 11, 2008 | 08:03 PM
EBR53's Avatar
EBR53
Related question...
I've got the car up on jack stands doing a rear sway bar, brake lines, ATE, etc. Conveniently, putting in MTL was on the to-do list and I happened to have 3 quarts on the shelf from the last car.
Bentley indicates (and I knew this ) that the fluid should be warmed up. Can I warm it up in neutral on the stands or do I need to drop it (putting the wheels on first) and tool around? It would save me a little time if I can but if not... that's just another couple beers worth of effort.
Old Apr 11, 2008 | 10:21 PM
resmini's Avatar
resmini
Originally Posted by EBR53
Related question...
The stuff pours very easy, seems to me like just leaving the plug out for a while would drain everything.
CardinalsRule
Jun 11, 2016 04:34 PM
molala
Oct 2, 2015 01:53 PM
Sep 3, 2015 03:01 PM
Sep 3, 2015 02:06 PM
Sep 2, 2015 09:05 AM
