GrassRoots Garage Installs @ the Dragon
Old Apr 6, 2008 | 08:02 PM
Grassroots Garage's Avatar
Grassroots Garage
Once again, the Dragon is upon us. This will be our 3rd MOTD and as in the past, some of our services will be available on site. We plan to bring a small assortment of goodies, however, if there is something particular you would like us to provide or install for you, Please let us know soon so I can make sure it comes with us.
We are a dealer/installer for most of the big names in the MINI aftermarket and some of the small ones... there is not much that we cannot get, just ask. As always, we would be happy to make recommendations.
Please use this link here http://grassrootsgarage.com/contact.html to contact us, or call 336-476-8551
Cheers,
Dan Zipkin &
Sumpter Smith
GrassRoots Garage
Old Apr 15, 2008 | 08:30 PM
surreptitious's Avatar
surreptitious
GRG Lines and Carbotech Brake Pads Availbility?
Great, Your install of the Quaife LSD, Mini Mania Light Weight Flywheel, and SPEC 2+ Clutch, worked out Great, Major difference, Felt like I was driving with the Ebrake on the whole time prior to the install. It is a major, WOW! factor, Thanks. Just in time for the "Dragon".
Question, Will you be able to install the great new GRG Brake Lines,
https://www.northamericanmotoring.co...rg+brake+lines
For my 06/03 MCS, Would like the traditional Silver braided lines, although the colored red and blue look great. What type of Brake Fluid will you have available? Will you have any of the Carbotech pads?
http://www.therpmstore.com/carbotech/
I would like to use a combo AX6 and XP8 setup, or would you recommend the bobcat setup, could these be ordered for Dragon or pre-Dragon Install?, I believe these will preform as well as some big brake applications, but an OEM setup. Idea of Cost on each and all plus install? Thanks
Old Apr 16, 2008 | 08:08 AM
Grassroots Garage
I will have both the brake hoses and an assortment of Carbotech pads available for purchase and installation at the Dragon. I will also have Pentosin Racing brake fluid (slightly better than SuperBlue). The XP8/AX6 combo is great for the track, but needs some heat to work properly. Because of this, I don't recommend them for the street. Bobcats are great for aggressive street driving and autocross. Bobcats are $122 for the front and $118 in the rear, The brake lines are $135 at the Dragon, and 1 liter of brake fluid is $16. Installation prices will vary depending on how much we are doing and discounted for overlapping work.
adrchn
Aug 13, 2019 02:11 AM
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
squawSkiBum
Oct 2, 2015 09:21 AM
flredmini
Sep 3, 2015 07:15 PM
