Drivetrain California Smog Cooper S
I just put my car on the new dyno smog for California to see what it was pumping out, and the tech told me its very clean. So no worries, maybe except for the new pricing which is expected to be $60 compared to current $30. My mods consisted Pulley, Evo ECU, Supersprint Header and cat-back, and BMP intake. You'll need to install the stock intake since none of the aftermarket intakes for the S is carb approved yet. As for the header they didn't see it. I had all my mods on during the pre-test.
Numbers from the results: (Averages) @ 2875 rpm
HC ppm: 15 (Max: 130)
NO ppm: 18
CO%: 0.00 (Max: 1.00)
CO2%: 15.3
O2: 0.1
NO ppm: 18
CO2%: 15.3
O2: 0.1
>>If a MCS with all those mods can pass smog then why are they so strict about emissions and intakes here in CA...
It has to do with that part about the govt having that extra edge of control over you, even if it's little things like an intake.
<<My mods consisted Pulley, Evo ECU, Supersprint Header and cat-back, and BMP intake.>>
Cal - R U running the high flow cat or stock?
This is very good to hear as Southern NY is as tough as you are these days.
silence2-38554
98
Sep 21, 2016 02:52 PM
PelicanParts.com
Aug 14, 2015 11:07 AM
