Wheel offset does what?
Old Apr 2, 2008 | 08:12 AM
DaveTinNY's Avatar
DaveTinNY
Forgive my naivete'... is a wheel offset some sort of spacer that has to be mounted between the wheel and the hub? Sort of similar to a centering ring?
I'm looking at all the aftermarket wheels and notice that many require an offset of some millimeter dimension.
TIA
Old Apr 2, 2008 | 08:24 AM
Wake|MCS's Avatar
Wake|MCS
Offset is used to determine how far IN or OUT the wheel will be in your wheel wells. Certain wheels need a minimum offset so that they don't rub on the suspension components or inner wheel liner. Same goes for some wheels that rub on the fender trim.
It is NOT a spacer, although spacers do affect offset, but that's not what you asked lol.
Hope this helps.
glnr13's Avatar
glnr13
offset is a spec on a wheel just like the width and diameter are specs.
stock offset for many MINI wheels is around +48mm for the 7" wide rims.
that means if you were to put a line down the middle of our 7" wheel and then put 48mm outwards that is where the hub will meet the mounting point of the wheel.
Old Apr 2, 2008 | 12:22 PM
aem421's Avatar
aem421
This might help you...
http://www.tirerack.com/wheels/tech/...jsp?techid=101
Old Apr 2, 2008 | 12:23 PM
aem421's Avatar
aem421
or this one...
http://www.1010tires.com/WheelOffsetCalculator.asp
Old Apr 2, 2008 | 11:20 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
TIA
If you go to tirerack.com and enter your year and model of MINI, it automatically finds which wheels will fit given stock suspension.
You will notice a range of offsets that will work within a given size wheel diameter often about +37mm to +45mm.
Numbers that are less positive will allow the wheel and tire to sit further outward from the wheel well while numbers that are more positive like +45mm will be more inside the wheel well.
Negative offsets are not for the MINI. You can use spacers to make the wheel offset less. A wheel with +45 offset with 5mm thick spacer will change the positive of the wheel so that it fits like it had +40mm offset.
Offset is also written with an "et" in front of it. so "et 45" is the same as +45mm.
Old Apr 6, 2008 | 05:42 AM
DaveTinNY's Avatar
DaveTinNY
"Numbers that are less positive will allow the wheel and tire to sit further outward from the wheel well while numbers that are more positive like +45mm will be more inside the wheel well."
This makes perfect sense. Thanks to all for your responses!
SosoMINI
Nov 22, 2015 03:17 PM
madmax88
Oct 26, 2015 01:45 PM
StuRat
Aug 24, 2015 06:24 PM
Mini'mon
Aug 16, 2015 04:15 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
