Suspension RSB comparison
Old Apr 2, 2008 | 04:51 AM
freeskier's Avatar
freeskier
RSB comparison
im trying to set my MCS up to oversteer a little bit and cant decided on a reas sway bar. would the alta 22mm or th Hsport 25mm be better for my purpous? i have been hearing that beause the Hsport is hollow and the alta is solid, its the same thing.
Old Apr 2, 2008 | 04:59 AM
RedSkunk's Avatar
RedSkunk
I do believe they have nearly the same stiffness since the one is hollow. You can probably find published "% stiffer" numbers if you dig a little - I know ones exist for the Alta (try their website).
I would go with whichever you can find a better deal on, or if the H-Sport has easier bushings to lube / it doesn't need lubing, then that'd be nice too. My Alta is noisy when the temp drops below 40 or so.
Old Apr 2, 2008 | 05:03 AM
freeskier's Avatar
freeskier
ok, i will look around fo stifness numbers. if anyone has any, that would be great.
Old Apr 2, 2008 | 07:24 AM
UKCoopeR's Avatar
UKCoopeR
i know the h-sport website has the stiffness percents for all three of their swaybars
http://www.hotchkis.net/c-803-02-06-...-cooper-s.aspx
Old Apr 2, 2008 | 09:56 AM
freeskier's Avatar
freeskier
Alta 22mm rear bar is 213, 260 and 329% stiffer than stock
Hsport 25.5mm rear bar is 226, 294 and 383% stiffer than stock
BackroadRunner
Sep 29, 2015 08:06 PM
Keet
SCCA Solo and ProSolo
Sep 20, 2015 01:02 PM
Keet
Sep 19, 2015 09:45 PM
MINI_42
Sep 16, 2015 02:01 AM
Sep 11, 2015 11:09 AM
