R50/53 Please help me - I am new to MINI
Old Mar 25, 2008 | 07:51 PM
jasonpig's Avatar
jasonpig
my question is , does the mcs and the N/A mini use the same engine.
if there is different, please tell me the detail. and are those engine DOHC or SOHC
thank you
Old Mar 26, 2008 | 05:59 AM
DixonL2's Avatar
DixonL2
The supercharged motor has beefed up internals to handle the boost. So no, they're not the same. Well, maybe the block...
Old Mar 26, 2008 | 07:12 AM
cmb5286's Avatar
cmb5286
im pretty sure both engines are sohc
Old Mar 26, 2008 | 07:14 AM
cmt52663's Avatar
cmt52663
thank you
same basic motor, which is a 16 valve single overhead cam displacing 1598cc
the Cooper S gets stronger parts to help manage the boost, including
1. crankshaft is made from forged steel instead of nodular cast iron
2. connecting rods are also forged steel instead of non-coplanar powdered metal
3. valve materials are higher spec
Old Mar 26, 2008 | 08:49 AM
jasonpig's Avatar
jasonpig
thanks guys.
what about the mini cooper from 2007+?
what kind of engine is that? any diff between the mini coopers and the basic mini?
Old Apr 1, 2008 | 08:26 PM
jasonpig's Avatar
jasonpig
pump it up
Old Apr 1, 2008 | 09:30 PM
noraa's Avatar
noraa
the non S engine block is made from iron, and the cooper S is all aluminum...anyone want to clarify, my memory is bleh.
Old Apr 2, 2008 | 05:25 AM
rhawth99's Avatar
rhawth99
For everything you always wanted to know about '07+ engines:
http://www.motoringfile.com/2004/12/...nge_in_detail/
Dec 23, 2015 10:36 AM
Dashdog
Aug 10, 2015 06:17 AM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
