Vibration Rattle Is Driving Me Nuts...
Old Mar 24, 2008 | 03:32 PM
WetNoseRanch's Avatar
WetNoseRanch
Ok, agreed that going nuts is a short ride but this "rattle" which really sounds like plastic pieces vibrating happens mostly on rough freeway concrete. It started out having to be just the right type of pavement to make it happen but yesterday I had it almost all the way home on a 40 mile drive
It sounds like it's coming from the right side door or the right side of the passenger seat. I've almost driven off the road trying to figure out what it is, I swear it's getting worse.
I've pushed and pulled on almost everything I can think off to no effect.
I know that if I take it to the dealer (which is 90 minutes away) I will get one of those "cannot duplicate" statements - been there, done that with other cars.
Anyone have any ideas or have this happen to them? This is not a mild buzz now and then but a persistent vibration rattle (at certain speeds or surfaces).
Old Mar 24, 2008 | 03:37 PM
funkdaddy's Avatar
funkdaddy
Yeah, I get this too. It is the plastic pieces that make up the door interior. Mine is slowly getting less and less worse... how many miles on yours?
Old Mar 24, 2008 | 03:44 PM
emtrey's Avatar
emtrey
try under dash on passenger side--I found a vibrating panel under the dash that made me crazy. I pushed some soft sided velcro in between the panels and the noise vanished. Even thoight it was underneath, it sounded like a dash rattle. see picture below
Old Mar 24, 2008 | 03:46 PM
ENGINE 58's Avatar
ENGINE 58
sometimes it can be the seat belts in the rear seats. they can rattle on the hard plastic sides of the interior. mine was doing this and i just put the seat belt clip all the way up and used the lil plastic holder to keep them there.
Old Mar 24, 2008 | 04:00 PM
rattmobbins's Avatar
rattmobbins
Welcome to the world of quirky British cars.
Rattle free is never mentioned in MINI advertising you'll notice.
Old Mar 24, 2008 | 04:14 PM
Charlie Croker's Avatar
Charlie Croker
Several options and solutions come to mind, but might seem to be insensitive to your problem, like wear ear plugs, or get a really loud exhaust, but my favorite is to turn my freaking music up above the rattle.
But to quote rattmobbins:
The dealer will never find the buzz. I have one coming from the same area that you discribe and I'm going to try emtrey's idea first!
Good luck and let us know how it turns out!
Old Mar 24, 2008 | 04:23 PM
r56mini's Avatar
r56mini
rattles are often caused by the bundles of wires inside rubbing against the inside surface.
Old Mar 24, 2008 | 04:55 PM
jimmy_racoon's Avatar
jimmy_racoon
Take her in...
My '05 Cooper had a similar issue. On the second cross country trip, we decided it was too much to tolerate. Rattle, squeeks, vibrations...whatever you call it, it was distracting from our motoring fun!
Took her into the dealer along with a couple minor issues. They knew of the problem, didn't question it, and proceeded to sound-proof the MINI. It was unbelieveable what a difference it made! They put velcro and spacers in and around the dash, etc.
Best yet, it was considered warranty and cost me nothing!
Worth a try...motor on.
Old Mar 24, 2008 | 05:05 PM
WetNoseRanch
About 1500. The rattle started just a couple of hundred miles ago.
Old Mar 24, 2008 | 05:06 PM
WetNoseRanch
Thanks! I'll try that one right away - it does sound like its in the dash except when it sounds by the door, or the seat, or the....
Old Mar 24, 2008 | 05:07 PM
WetNoseRanch
Wow - you have a great dealer!
Old Mar 24, 2008 | 05:08 PM
WetNoseRanch
Yeah, I tried that because I thought the same thing - and did the same thing....
Smart minds think alike.
Old Mar 24, 2008 | 08:28 PM
Benibiker's Avatar
Benibiker
I have the same problem but it's dependent on temperature for me, in the cool mornings it makes the sound and during mid day it's gone. You pretty much need to get a passenger to ride with you or have them drive your car while you search for that evil dirty rattle/buzz
Old Mar 24, 2008 | 08:45 PM
pyskacz's Avatar
pyskacz
My R55 has developed the rattle lately also ...it has 1500 miles on it. I definitely will have to try the velcro idea, before I take it to the dealer. I did notice when I turn the radio volume up past a certain point-it does disappear
Old Mar 24, 2008 | 09:45 PM
gjhsu's Avatar
gjhsu
Another thing to try (my car does this):
My door lock (the little BMW nipple thing that sticks out the top of the door) rattles on rough roads, so I just lock the door, and it stops. I guess the little plastic cap that makes up the door lock is just BARELY loose from whatever metal is underneath it to cause this.
My other plastic rattle that I fixed this weekend was the knee panel under the steering wheel. I just shoved it a bit to reseat the clips and all is good.
Old Mar 25, 2008 | 09:37 AM
pyskacz's Avatar
pyskacz
Guess this is one more thing that I'll have to try.
Old Apr 1, 2008 | 07:56 AM
D3m0N's Avatar
D3m0N
I removed a dash rattle by simply removing the torx bits from either side of the top dash panel removing the panel and placing a piece of an old blanket up on top before replacing the dash.
50 more rattles to go
Old Jul 5, 2008 | 07:05 AM
orangecrush's Avatar
orangecrush
Well??? An update for the rest of us? LOL
I just turned 2K miles and noticed on a trip to Charleston that I have a dash "buzzing/rattle"
Where's the mad smilie???
Old Jul 5, 2008 | 12:12 PM
miniclubman's Avatar
miniclubman
I also have a dashboard rattle, and I'm pretty sure it's coming from the right dash vent assembly. There's a large round plastic piece at the extreme right edge of the dashboard, near the passenger door. You need to have the passenger door open to see it. If I gently push on that piece it makes the exact creaking/squeaking sound I hear when driving over rough pavement. Actually, the whole right dashboard vent assembly may be squeaking/creaking, but the round plastic panel is my main suspect as of now. I'll have the dealer check it out next week, I'm already scheduled for a different service.
Old Jul 6, 2008 | 04:17 PM
npalao's Avatar
npalao
I have a very loud rattle coming from the engine compartment, the dealer could not find anything after 2 months with the car and several SERIOUS parts changed. Still there. Another one just developed by the driver door, just found out 5 minutes ago that the window is moving very slightly in and out on rough roads. I am looking for the solution. Try that!
Old Jul 6, 2008 | 04:32 PM
orangecrush
You'll have to look it up but I read something about a service bulletin about a window. Perhaps someone else can give you more info but if not, check with the dealer.
HTH's,
Mark
Old Jul 6, 2008 | 05:27 PM
npalao's Avatar
npalao
Thanks OJCrush! I have looked at a couple of those, but they mainly focus on squeaky windows. Mine is a light rattling sound. Stupid dealer told me that the seal around the door was worn. Today while detailing the car I noticed the rattle when I wiggled the window while the door was opened. The other side is nice and tight!
Old Jul 6, 2008 | 06:21 PM
orangecrush
Sounds to me like the glass needs to be adjusted. Too bad you're not in NC. You could drive it to my bodyshop, I'd adjust it for you.
Good luck.
Mark
Old Jul 7, 2008 | 07:14 AM
npalao's Avatar
npalao
It has been adjusted 3 times man! First dummies changed the entire electric assembly, but left the window not properly adjusted, second time around was just adjustment, which left the window nice and even and flush, but with the rattle even worse. I am ordering the snap fasteners for the trim, and will check it myself. The snaps need to be changed anyway, some are loose. Do you know how many there are and if they just snap out by pulling them (the bottom ones)? I think the upper part just slides upward once the bottom ones are out. Thanks.
Old Jul 11, 2008 | 06:19 PM
miniclubman
Rattle: Fixed!
The creaking that developed on the right side of my dashboard a couple of weeks ago was fixed by the dealer today. It was something in the right dashboard vent assembly, a plastic-on-plastic creaking whenever I went over a rough patch of road. Habberstad MINI took care of it, and when I hit a nice rough patch on the way home - no creaking!
