R50/53 automatic transmission problems
Old Mar 22, 2008 | 10:28 PM
zigermanzz's Avatar
zigermanzz
Alliance Member
Hi all
My automatic mini cooper "s" is not shifting smoothly. I am taking it to the dealer next week. Any ideas what could be the problem? i hate being tossed around by my beloved dealer and would like to have some insight as to what the problem could be: software upgrade, service bulletin, recall, recurrent auto trans problems....anything that you would like to share with me.
Thank you.
Old Mar 22, 2008 | 11:04 PM
Alpha Motoring's Avatar
Alpha Motoring
When you say not shifting smoothly what do you mean? How many miles is on it? Have you tried unplugging the battery and see if your shifts will improve?
Old Mar 22, 2008 | 11:25 PM
zigermanzz's Avatar
zigermanzz
Alliance Member
Hi there
When i take off, the first change(from 1st to 2nd) is smooth but the second(from 2nd to 3rd) makes the car jerk a little..the car has 62000kms, so around 38000miles. it is still under warranty, but i never changed the ATF on it. Was I supposed to? What are the manufacturer's recommmendations as to ATF?
No i didnt try to unplugg battery. How would it fix the problem?
Old Mar 23, 2008 | 09:54 AM
Alpha Motoring
Pulling the battery resets the car, sometimes the computer remembers a weird shift pattern that isn't smooth, having the computer re-learn the shifts might help, but I'm not so sure it would in your situation.
Old Mar 23, 2008 | 12:49 PM
zigermanzz's Avatar
zigermanzz
Alliance Member
ok, will try it and see what this will do.
thks
Old Mar 23, 2008 | 12:53 PM
ClubmanS's Avatar
ClubmanS
The transmission oil is "lifetime" but you should replace it at around 40K-50K miles as a preventive measure. Try disconnecting the battery and see if that clears the adaptive settings. If that doesn't help, maybe a visit to the dealer is warranted.
Old Mar 23, 2008 | 01:38 PM
Alpha Motoring
How do you change it? I heard it wasn't 'changeable'?
lalroma
20
Apr 2, 2022 06:19 PM
minicoclub
Aug 25, 2015 09:07 AM
Aug 19, 2015 12:51 PM
Aug 19, 2015 08:28 AM
Aug 19, 2015 08:27 AM
