I'll be in Las Vegas for AMVIV. While I'm there, I'm going to have a set of H&R springs installed. I'd like to get it aligned before driving home. Would someone be able to recommend an alignment shop in Las Vegas?
Its always best to run the new springs for awhile till they settle into the new suspension, then do the alignment. I'd run them for at least two to three months before you get the car aligned unless your driving a lot of negitive camber and worried about the inside tire wear.
I asked a local mechanic I trust, and she recommended Georges Alignment & Brake at 3349 Meade Av
Las Vegas, NV 89102. Map is here and the map with directions from Palace are here.
