R52 How to remove rear interior panel?
Old Mar 14, 2008 | 06:23 PM
lsnover's Avatar
lsnover
I've tried to search around and there's tons of stuff here, but I can't find a thread showing specifically how to remove the rear interior panel from an 05 Mini convertible. Can someone point me to some specifics?
I need to pull the panel so my paintless dent guy can get access. He's pretty reasonable and does a great job when the obstructions are removed.
Thanks!
Lee
Old Mar 14, 2008 | 09:22 PM
Mishka's Avatar
Mishka
Must be a Hot Orange thing...
I'm next in line for the same info. My boot light has quit working. The bulb is good, and everything else is working so I'm thinking loose wire.
Old Mar 15, 2008 | 03:40 AM
lsnover's Avatar
lsnover
It's known as the Lateral Trim Panel in the mini parts list.
Hot Orange converts. rule. LOL.
Old Mar 15, 2008 | 09:00 AM
N2MINI's Avatar
N2MINI
No expert, but might help. roll back the rubber gasket running up edge. There is a screw behind triangle shaped rubber trim. Also a screw in one of the holes where the windscreen locks into place. Take bottom of rear seat out and undo all the bolts to the rear seat back, so it is loose and then you can pull up on the panel to unhook so to speak. At this point you can move it around pretty good but you can't remove it completely as the rear seat back is still attached thru a hole at the bottom. Your dent guy should have enough room to do what he needs to do, but know there is also kinds of stuff behind there. Speaker, wires galore, etc..
W0TM8
Dec 19, 2019 07:50 AM
Mini'mon
Aug 26, 2015 01:02 PM
chicohuahua
22
Aug 20, 2015 11:17 AM
xraycat
Aug 12, 2015 02:36 PM
