Voltage Cold Air Intakes
1FastMINI.com has added Voltage CAI to our product line
The 53R is a unique design that incorporates as much technology as we could fit into oem parameters.The fully composite, hand layed intake holds the same dimensions as the oem box so there's never a problem with fitting aftermarket strut bars and other accessories in the engine bay.It also uses the oem front fresh air feed as well as being completely open in the rear for the intake of cool air thru the vent below the windshield.The other feature that sets it apart from the rest other than looks and finish is that we have built a true velocity stack into the design that creates a ventury effect to create maximum HP and quick smooth throttle response.The 53R comes ready to install in the color of your choice with a pre oiled high flow dual stage foam filter.
chrisx18240
26
Mar 16, 2022 09:56 AM
