R50/53 centering rings
Old Mar 11, 2008 | 01:31 PM
freeskier's Avatar
freeskier
centering rings
my 02 MCS came with aftermarket wheels wrapped in snow tires and the stockwheels for the summer. when i took off the aftermarket there were red rings on the hub, do i need these to re mount my stockwheels? thanks
Old Mar 11, 2008 | 01:37 PM
Modshack's Avatar
Modshack
Centering rings are used to make a universal Wheel hub centric to the car. Different aftermarket wheels have different bores, so you select the Ring to match your combination. You shouldn't need them with the stock wheels..
Old Mar 11, 2008 | 01:41 PM
Brewmeister's Avatar
Brewmeister
Interesting question as most of us run after market wheels with summer tires and change back to stock in the winter. Your stock rims should not required rings.
Old Mar 11, 2008 | 01:56 PM
jonnieoh's Avatar
jonnieoh
+1
By the way, there are plastic centering rings that come with some wheels, and there are metal ones. Obviously, the metal ones would be recommended. It is worth upgrading to metal rings.
Old Mar 11, 2008 | 03:09 PM
freeskier's Avatar
freeskier
ok thanks wheels are switched and im frantically trying to sell them
Aug 25, 2015 07:11 AM
Aug 19, 2015 12:51 PM
Mini'mon
Aug 16, 2015 04:15 PM
Aug 12, 2015 01:24 PM
