R50/53 What if wrong PS fluid is used?
What happens if I put ATF fluid in a new PS pump? I just realized that I wasn't suposed to do that. It's been in for almost 6 months.
Can I flush the fluid, or will I need to replace the pump again?
ps fluid
As an example, check out: http://www.carcare.org/Fluids_Filter...ng_fluid.shtml
Ok, maybe I've got that wrong. I used regular PS fluid. I used GUNK brand PS Fluid, not Automatic Transmission Fluid. Sorry I got that wrong. The MINI requires a special hydrolic PS fluid not the typical PS fluid.
steering fluid
Good luck! Greg
If it has been 6 months on that stuff, I'd say you are in the clear. If it was to destroy something, I would think it have done so already.
When my powersteering was low I added the BMW stuff it recomends. I forget what exactly, but it's listed on the reservor cap. It was only $24 with tax for a huge bottle at the BMW dealer here.
Mini used Pentosin CHF 11s. If you put ATF in or any other fluid, as long as it was a small amount you should be ok. i would still get it flushed asap. make sure you always use CHF 11s other wise you can cause wear issues within the rack.
Ok, I forgot to mention my prior issues. About 2 weeks ago I noticed my steering got "notchy." (I had just jacked the MINI's front driver's side end up to do an oil change if that makes any difference) I talked to the dealer and they said it sounded like the rack. Went in to have it looked at, and they said the rack was leaking. I had it up on a lift this weekend at a different local dealership, and there is no evidence of leaking rack. The boots are not full of anything, nor are they leaking anything at all. Recently the notchy-ness has stopped. So, something is or was causing a problem. I guess I'll just flush it pretty good a couple of times to be safe and see what happens, think?
Sep 22, 2015 02:05 PM
