Questions about the R56 trailing arm for R53 conversion kit?
Old Mar 3, 2008 | 10:41 AM
MotoringSpeed_gnat's Avatar
MotoringSpeed_gnat
I started this thread if there are any questions about the R56 Trailing Arm for R53 Conversion Kit we offer.
Parts included:
1 Trailing Arm - Aluminum Left 33-32-6-765-377
1 Trailing Arm - Aluminum Right 33-32-6-765-378
2 Self tapping Screw M14x1.5x101 33-32-6-770-089
2 Bushing Stopper 33-31-6-761-779
1 Bushing Bracket Left 33-30-6-772-665
1 Bushing Bracket Right 33-30-6-772-666
2 Hex Bolt with Washer M12x1.5x83-10.9 33-30-6-768-048
2 Self Locking Collar Nut M12x1.5-10ZNS3 33-32-6-760-374
2 Hex Bolt with Washer M12x1.5x100 33-30-6-772-658
2 Adjusting Plate 33-32-6-767-869
2 Cage Nut M12x1.5-10ZNS3 33-30-6-770-138
8 Hex Bolt with Washer M10x75-10.9 33-50-6-771-928
2 Rotational Speed Sensor Rear axle 34-52-6-773-020
You will also need to order the Helix R56 Rear Shock Bushings
Old Mar 9, 2008 | 08:17 PM
Dr Obnxs's Avatar
Dr Obnxs
Some other items...
like Ryan found in the Alliance article, you need to do something about the sway bar end link. The bolt on the R53 one is too short, as is the one for the Alta R53 sway bar. You can grind down the boss like Ryan did, or get a end-link for the R56. I haven't called Alta yet to see if they have parts to modify the R53 adjustable end link.
My arms didn't have tapped holes for the speed sensor allen head bolt. It's a M6x1 thread so you can buy a tap.
For those with the TCE larger rear brake rotors, you have to grind down the arms a bit otherwise the button head screws will interfere with the control arm and the caliper frame wont seat properly.
Hope this helps....
Matt
Old Nov 1, 2008 | 03:04 PM
Mahatma Kane's Avatar
Mahatma Kane
Since it seems this conversion (which is quite involved and expensive) is done to reduce unsprung weight, what exactly is the weight difference between R53 steel and R56 cast alumium rear arms?
Old Jan 2, 2009 | 04:07 PM
SCORPIO's Avatar
SCORPIO
I have read the weight difference to be 12 pounds.
Old May 5, 2011 | 10:09 PM
slickwilly8's Avatar
slickwilly8
Is this kit still available?
Old Feb 21, 2012 | 08:07 AM
rustyeuro's Avatar
rustyeuro
bump, did you guys actually piece together this kit?
Old Feb 21, 2012 | 08:34 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We actually still offer this conversion, as I've done it to one of my cars. You actually don't need all those parts, but it's still expensive. I'll put it together for anyone that wants.
Old Feb 21, 2012 | 09:38 PM
rustyeuro's Avatar
rustyeuro
what parts are absolutely necessary for this conversion and how much is it?
i guess i thought i had a pretty good idea what was needed until i saw that list.
Old May 23, 2013 | 02:16 AM
DSCS's Avatar
DSCS
Hello everyone. I am doing the R56 trailing arm conversion for my R53, so I need some help from you where can I buy those Adapter online?
Thanks.
Old Nov 11, 2022 | 08:52 PM
Eddie Vergara's Avatar
Eddie Vergara
Folks,
Can the R52/R53 bolts be reused when doing the R56 trailing arm install? That is:
3x Pivot Arm bolts
2x Brake Caliper Mounting Bracket Bolts
1x Shock bolt
1x Eccentric bolt
I bought the trailing arms from a 3rd party, but all they included are the wheel bearing bolts. I'm trying to determine what I need to go hunt down at junk yard or buy online vs. just re-use from my R52.
Thanks for any feedback.
Old Nov 15, 2022 | 08:07 AM
WayMotorWorks
Vendor
You need the R56 bolts for the shock, control arms to attach to the trailing arm, and bushing. Look at our set as it comes complete with everything you need:
https://www.waymotorworks.com/alumin...rsion-kit.html
Originally Posted by Eddie Vergara
Folks,
3x Pivot Arm bolts
1x Shock bolt
1x Eccentric bolt
andrewjg1994
Jan 29, 2021 07:45 PM
W0TM8
Dec 19, 2019 07:50 AM
wkp1219
Nov 13, 2015 07:52 AM
Minibeagle
Aug 13, 2015 10:00 AM
