Drivetrain Pease post your Cooper S Dyno's HERE...
>>All runs are with:
>>Madness intake
>>MiniMania pulley
>>Supersprint header
>>Magnaflow exhaust
Bisch,
is this with the stock cat or cat-free? I only ask because the SS header doesn't come with a cat.
To keep this thread clean & to the point, I'll delete this post if you note your cat set-up in your mod list.
>>All runs are with:
>>Madness intake
>>MiniMania pulley
>>Supersprint header
>>Magnaflow exhaust
Bisch,
Modifications: PROMINI Pulley, PROMINI Software, PROMINI Water to Air Intercooler, PROMINI Intake, PROMINI Street Cam, Plug Wires, Supersprint Headers, Supersprint Cat, Supersprint Exhaust, H&R Front and Rear Sway Bars, H&R Coilovers, K-Mac Front Camber/Caster Plates, K-Mac Rear Camber /Toe Kit, Powerflex Bushings, PROMINI Sway Bar Links, PROMINI Stress Bar, Ta-rox Big Brake Kit, Stainless Steel Brake Lines, PROMINI Instrument Cluster, Schroth Harnesses, BBS RGR wheels with Kumho Tires.
The chart is at the wheels...the torque needs to be divided to get the listed ratio (qwirk with the dynapack software)
>>Hmm. The dyno charts just posted by binkydognose show stock MCS wheel max HP of 127 while the consensus seems in the neighborhood of mid to high 140's.
That dyno may read lower than other machines perhaps, that's what Randy Webb seemed to think, the difference is more telling. Thought it would be good to post anyway.
:smile:
:smile:
Thanks but I'm confused- I can't see many of the posted dyno sheets.
Bisch BTW, your car is running very, very rich. Actually I'm pretty sure the limit of the o2 sensor is 10:1 and that's why it held there. 12 to 12:5 is optimum for power.
Mine is at the crank.
This dyno was while we were blowing cold Co2 over the intercooler. Problem being that the MCS intercooler is very difficult to cool during a dyno with just fans. I feel that the 215 hp is about what I'm getting during the cooler/cold months. Probably 200 hp in the summer months.
Alta 15% * Alta CAI * Alta Top Mount Intercooler * Alta Oil Catch Can * Miltek Header/Cat * Miltek Catback * Unichip * IK22 *
