Just had my sc pulley put on last weekend, and yesterday I had the MINI dyno'd again. To date, my only motor mods are alta intake, and pulley. I never had the chance to get baseline stock numbers on the dyno, but a few weeks ago I did get numbers with the alta intake. I was able to get 168hp and 154ft-lb of torque. After the pulley I pulled down 192 hp and 170ft-lb torque. Both dyno runs were done at the same location and same conditions. So, 24hp increase from a pulley? hard to believe, but I can definitely feel the difference. I plan on getting an exhaust next, and going back to the same dyno and posting those results. pics of the results below.
Man, I hope those numbers are correct. I'm putting an ALTA CAI on soon, and a pulley on this summer, hopefully... same mods, and hopefully the same incredible results!!
Did you happen to get Air/Fuel ratios along with the power dyno? That would be interesting to see.
sorry, didn't have the option to get that information.
Originally Posted by beken
I just bought a pulley from Alta last weekend but haven't installed it yet. This is good information.
Have you considered using cooler temperature spark plugs or remapping the ECU yet?
Not yet. I will be purchasing the new Alta black exhaust in the next few weeks. My plan is to add a mod, get it dyno'd, and add another mod etc. and just track each components improvement, unfortuantely I never got a factory dyno run. A tune and/or injectors will come after the exhaust I figure.
I just had the Alta 15% pulley, Alta CAI, and Jardine cat back exhaust installed. BAT OUT OF HELL baby! Slapped an H sport 25" sway bar on too. See you at the dragon in my '05 BRG/BLK with checkered mirrors. Wave when I blow by!
Yeah, I watched about 3 seconds of it... Would have listened to the hole thing without the music
Welllll.....maybe u should have watched for a few more seconds. the music was playing while i was just rolling, or working my way thru the gears. the music fades when I start the actual pull and doesnt come back til the end after the 2nd pull. So both pulls are just the car. not music.
Originally Posted by zmanrz
nice numbers man.....
i'm a little confused about your numbers.
i have CAI, 17% alta v2 pully, meagan header, alta 2.5 in exhaust,
i put down 191HP 170 TQ
how many miles does your car have???
i'm at 68k and counting....
wonder if it makes a difference???
I imagine there are a lot of things that can factor into the numbers. Temperature, elevation, gear, factory hp, etc. however, my car has about 38k miles.
