R50/53 Cruise control
Cruise control
This probably is the dumbest question here but in the 3 months I have had the car I haven't found it or come to the conclusion it doesnt have it, but how would I know if the car has cruise control? I was under the impression cars came standard with it now. After all my '88 BMW has it, I would have thought cruise control was a standard thing.. With the odd locations for stuff in the mini (bonnet latch for example) is the cruise control lever like.. in the trunk or the glove box?
Was it an additional option in '03 for the R50 to have cruise control?
If I dont have cruise control the 10hr drive to MOTD is gonna be a loong drive...
Well that sux... for me... dang, its gonna be a long drive.
Dont suppose I could go to the dealer and have them install it... could I?
I considered the mod for a while, but doing it right (i.e., OEM parts) turned out to be prohibitively expensive, as Gromit attests. I just decided to live without it.
I've done just over 1,000 miles at a single pop while relying on the gray cruise control that sits directly between my ears. I missed the other version a lot less than I would have otherwise thought. The engine revs at highway speed, responsiveness, and sound seem to keep me in tune with the speed I'm traveling and you sort of fall into a groove. The only fatigue factor for me is when I rest my leg too heavily against the down tube for a long stretch.
My suggestion is to take the back roads to MOTD. You'll be spending so much time accelerating out of the sweepers that you'll not even be thinking about cruising...
I've been trying to figure out adding cruise control to an R53 that currently doesn't have it installed. I've always had cruise control and used it everywhere so not having it is a real problem for me. Here's a thread that seems to answer some questions;
https://www.northamericanmotoring.co...d.php?t=128591
Keep checking on having it done, maybe it's not as expensive as we think it is.....good luck.
If it's any consolation, you can get better gas mileage without the cruise control engaged. I checked this out a few times thanks to a 50 mile commute (1-way). I consistently got 1-2 mpg better without cruise in use.
