edge racing bundles
Old Jul 19, 2003 | 10:29 PM
weaverpsu's Avatar
weaverpsu
i noticed that when i clicked on 16 inch wheel/tire bundles for the mcs on Edge Racing's site that all of the bundles come with 205/55/16 tires. Isnt 215/45 a better choice? wider and less sidewall right? this site confused me.
Old Jul 20, 2003 | 08:21 AM
Danbo's Avatar
Danbo
Yes thats correct, But it will also give you a stiffer ride because of a lesser height of a side wall...
Old Jul 20, 2003 | 08:29 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
If you go to tirerack.com and choose any of the 16" rims you get matched with 195/55-16 tires which can be changed to something else. Many tire companies will go with the safest least aggressive option in keeping with the stock tire options. Moving to something far off the stock size could risk voiding your warranty- check with your dealer. The 205/55 and 215/45 sizes will both work even if you lower the car by one inch front and rear. There may be slight differences with load capacity, tire height, and tire weight. The 215 is the widest tire by 10mm and the 205 is similarly wider than the 195.
Old Jul 20, 2003 | 08:30 AM
Sportech's Avatar
Sportech
The 45 series tire is 1.25" smaller in diameter than the 55 series tire. Don't do it!
Old Jul 20, 2003 | 12:55 PM
minhi's Avatar
minhi
you should get 205 or 215/50 tires. do not get the 55 aspect ratio tires! someone on a group run this weekend has them (also from edgeracing) and they rub even under light driving.
Old Jul 20, 2003 | 07:55 PM
weaverpsu's Avatar
weaverpsu
um... practically everyone i know (throught this site and at auto x) runs 215/45/16 with the falken azenis. I know its fine.
Old Jul 20, 2003 | 08:03 PM
orbhot's Avatar
orbhot
Not only that, but you will really need at least a 7 inch wide wheel for 215s (the factory 16s are 6.5).
Old Jul 21, 2003 | 05:48 AM
JohnW's Avatar
JohnW
this may help...
here is a link to a great wheel & tire info site that has a java calculator that lets you plug in old & new tire sizes. it then tells you the diameter and other differences, and even calculates speedometer error.
http://www.chris-longhurst.com/carbibles/tyre_bible.html
Old Jul 21, 2003 | 12:31 PM
Alex@tirerack's Avatar
Alex@tirerack
205/55 is tall for the car, not advised.
215/45 ( while not a tirerack recomended size, is widley used, and has a good diameter of 24.6, and has load bearing capacity the Mini requires)
Alex
Old Jul 21, 2003 | 12:38 PM
antsmini's Avatar
antsmini
Use Tire Rack instead. I used Edge Racing and they sent me a used wheel, and also the wheels did not work on the MINI.
Old Jul 21, 2003 | 11:26 PM
weaverpsu's Avatar
weaverpsu
still waiting for those SSR Comp R pics
Old Jul 23, 2003 | 12:38 PM
momini's Avatar
momini
Hey Ant,
How did things work out with the Apex wheels...any ideas on why you were having problems? Since seeing you at the Litchfield meet, I happened upon an MCS with the Apex2 wheels. Owner said he had no problem and they seemed to fit well (looked great too). I wish there were more choices of dark-colored wheels with polished lips to choose from.
Chibi2
May 19, 2016 03:46 PM
gnhovis
Dec 14, 2015 05:31 PM
pahg
Oct 5, 2015 11:50 AM
Island maser
General Discussion
Oct 1, 2015 01:09 PM
potterstein
Oct 1, 2015 07:10 AM
