edge racing bundles
i noticed that when i clicked on 16 inch wheel/tire bundles for the mcs on Edge Racing's site that all of the bundles come with 205/55/16 tires. Isnt 215/45 a better choice? wider and less sidewall right? this site confused me.
If you go to tirerack.com and choose any of the 16" rims you get matched with 195/55-16 tires which can be changed to something else. Many tire companies will go with the safest least aggressive option in keeping with the stock tire options. Moving to something far off the stock size could risk voiding your warranty- check with your dealer. The 205/55 and 215/45 sizes will both work even if you lower the car by one inch front and rear. There may be slight differences with load capacity, tire height, and tire weight. The 215 is the widest tire by 10mm and the 205 is similarly wider than the 195.
Not only that, but you will really need at least a 7 inch wide wheel for 215s (the factory 16s are 6.5).
this may help...
here is a link to a great wheel & tire info site that has a java calculator that lets you plug in old & new tire sizes. it then tells you the diameter and other differences, and even calculates speedometer error.
http://www.chris-longhurst.com/carbibles/tyre_bible.html
205/55 is tall for the car, not advised.
215/45 ( while not a tirerack recomended size, is widley used, and has a good diameter of 24.6, and has load bearing capacity the Mini requires)
Alex
Alex
>>Use Tire Rack instead. I used Edge Racing and they sent me a used wheel, and also the wheels did not work on the MINI.
Hey Ant,
How did things work out with the Apex wheels...any ideas on why you were having problems? Since seeing you at the Litchfield meet, I happened upon an MCS with the Apex2 wheels. Owner said he had no problem and they seemed to fit well (looked great too). I wish there were more choices of dark-colored wheels with polished lips to choose from.
Hey Ant,
Chibi2
May 19, 2016 03:46 PM
pahg
Oct 5, 2015 11:50 AM
