Suspension Rear sway bar
Old Feb 6, 2008 | 07:31 AM
grillhands's Avatar
grillhands
Rear sway bar
What exactly is the benefit of upgrading it?
Old Feb 6, 2008 | 09:43 AM
minimarks's Avatar
minimarks
Reduces understeer (push) in a turn.
Old Feb 6, 2008 | 10:09 AM
oxtox's Avatar
oxtox
thought i'd send you this link from my old forum. my wrx used to understeer horribly in factory form.. fortunately we can fix that easily! sway bars are great. companies intentionally make cars with understeer as they feel it's a safer alternative to a responsive (and to some overresponsive) steering car. my '05 M3 is the exact opposite with dcs turned off...wheeeeee! happy reading! http://forums.nasioc.com/forums/show....php?t=1152714
Old Feb 6, 2008 | 11:09 AM
Speedwing's Avatar
Speedwing
Upgrading my MC to a 19mm H&R rear sway bar is my favorite mod. My MC corners way better ..... flatter, no push, no squeal ..... just so much better it is hard to describe. It is well worth the effort to upgrade. I did mine by myself using directions found here on NAM.
Old Feb 6, 2008 | 11:42 AM
minimarks's Avatar
minimarks
Swaybar is to handleing as 15% pulley is to power....
Old Feb 6, 2008 | 02:54 PM
Dr. Pepper's Avatar
Dr. Pepper
I just installed a 19mm sway bar on my MCC and it made a huge difference in cornering. Much flatter and more responsive in the corners. Very neutral.
Old Feb 6, 2008 | 02:58 PM
Big-Daddy-Blue's Avatar
Big-Daddy-Blue
I just put the Alta 22mm, 3 way adjustment on mine. Set to the middle setting, it is great.
Old Feb 6, 2008 | 03:33 PM
AutoXCooper.com's Avatar
AutoXCooper.com
The IE 22mm with end links is a great value too. Link below to Ireland.
Old Feb 6, 2008 | 03:51 PM
hemiheaded18's Avatar
hemiheaded18
The only true way to understand it is to experience it. If I was to try and explain how my car with the 19mm Hotchkis feels, it's as if the car rotates in a turn compared to the push it used to have. Do it and you'll feel the difference.
Old Feb 6, 2008 | 06:51 PM
grillhands's Avatar
grillhands
Not one bad thing! I think im going to splurge and pick one up. Thanks everybody.
Old Feb 6, 2008 | 06:59 PM
Crashton's Avatar
Crashton
Yep the 19mm rear bar does help. I have one myself. At sane speeds it's great. Go fast enough & it will still understeer. I'm talking track speeds.
Old Feb 6, 2008 | 07:21 PM
RedSkunk's Avatar
RedSkunk
About time!
Old Feb 7, 2008 | 03:46 AM
grillhands's Avatar
grillhands
Originally Posted by RedSkunk
About time!
I know. I've been too concerned with the engine mods. I gotta start thinking handling
Old Feb 7, 2008 | 06:30 AM
MiniS AZ's Avatar
MiniS AZ
i just picked up a 19mm Alta Bar. What are most ppl setting it at? I was thinking about setting it at the stiffest. Thoughts?
Old Feb 7, 2008 | 06:47 AM
hemiheaded18
I had mine installed at Helix and they set it at the middle setting. Still a big improvement and allows for a little bit more in the future. I'd say middle so you can feel it but also so you can get used to it without the car getting out of hand too soon.
Old Feb 7, 2008 | 08:06 AM
succubus's Avatar
succubus
depends on what other mods you've done, you're driving style/ability, and what type of suspension your car has. For me, the stock suspension with FSB and USS needed the stiff setting. I've had half a mind to turn it back to the middle setting for safety on the street.
If you've got camber plates or anything else that reduces understeer, you'll need less rear bar. I think the safest thing to do is set it at its softest, and drive for a while. If you feel you need more, bump it up a notch. Adjustments are easy if you know how to take a wheel off.
Old Feb 7, 2008 | 12:55 PM
soNburst's Avatar
soNburst
did you get 19 or 22?
Old Feb 7, 2008 | 11:49 PM
hemiheaded18
19mm Hotchkis Sport bar. I could have gotten the Alta bar for about $20 less but I trust the name more and I like the stealthiness of the black bar.
Old Feb 8, 2008 | 04:45 PM
Crashton's Avatar
Crashton
I like the black color also, but I really like the grease-able bushings. Zerk fittings for the win.
Old Feb 15, 2008 | 04:38 PM
Minut's Avatar
Minut
Anyone know the weight of the H-sport 19mm bar? Weight of the stock MCS bar?
Old Jun 28, 2008 | 02:23 PM
silversmoke06's Avatar
silversmoke06
why would the weight matter?
Old Jun 28, 2008 | 03:35 PM
kapps's Avatar
kapps
Because lighter is better. It's been a while but my stock bar was definitely heavier than my 22mm H-Sport.
Old Jun 28, 2008 | 03:43 PM
Goodwood's Avatar
Goodwood
"Swaybar is to handling as 15% pulley is to power...." - minimarks
This sums it up quite well.
W0TM8
Dec 19, 2019 07:50 AM
pre shrunk
Aug 18, 2015 11:09 AM
Bennyboy
Aug 18, 2015 07:28 AM
nomar116
Aug 10, 2015 11:24 PM
OutMotoring
Aug 6, 2015 09:32 AM
