Aliagnment problem
Old Jul 18, 2003 | 07:53 PM
ultramini's Avatar
ultramini
Hi All,
My mini just pass 700 miles. However, my mini seems to have aliagnment problem already. I spoke with local dealer about it. They told me that they fix it before first 2000 miles. I wonder if anybody also have same problem.
Ultramini.
Old Jul 18, 2003 | 08:08 PM
dave's Avatar
dave
pug poo picker-upper
I know ficcion had an alignment issue with his 02 MINI right from the factory. It was realigned under warranty without further trouble to my knowledge.
Old Jul 18, 2003 | 08:21 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
If the wheels are not wearing the same then that is a sign of trouble or if the car tracks to one side when driving that could be alignment trouble.
You can have your dealer check it and realign as needed.
Old Jul 18, 2003 | 09:12 PM
ultramini's Avatar
ultramini
Thank you for the reply. I hope this is just a minor issue.
Old Jul 18, 2003 | 09:44 PM
minibel's Avatar
minibel
I had the EXACT problem. I severely pulled to the right. The seering is touchy enough let alone having to always correct. I was at about 500 miles when it seemed to get progressively worse. I called it in at 1400 miles and they informed me of the 2000 mile coverage.
Turns out it was a tire which they say was under inflated. I have been watching it and it has not gone down since... but Baron MINI took it in, checked it out and lent me a car for the day. All for an underinflated tire. So I hope yours is as easy as mine was to fix and I would check your air pressure.
They could have been feeding me a line of crap- but the problem was fixed so I dont mind.
Good luck!
Old Jul 18, 2003 | 11:02 PM
ultramini's Avatar
ultramini
Thank you. I will check it tomorrow. or it will take a whole day for me without a car if I take back to dealer for adjustment. :smile:
Old Jul 21, 2003 | 11:23 AM
Alex@tirerack's Avatar
Alex@tirerack
They most likely were not. the Right Front tire is easily the hardest used tire on the entire vehcile. Just another GREAT reason to check your air pressures regularly!
Alex
_________________
Alex ext 294
800 522 8473
Tire & Wheel forum moderator
www.tirerack.com
alex@tirerack.com
UncDeo
Nov 4, 2019 04:08 AM
tylewis
Sep 6, 2015 01:07 PM
mikeandtricie
Sep 4, 2015 01:42 PM
mimaal
Sep 4, 2015 09:09 AM
Sep 2, 2015 09:05 AM
