Brake question
Old Jan 27, 2008 | 06:05 PM
D3m0N's Avatar
D3m0N
Brake question
I have replaced my front brakes with ferodo pads and Brembro rotors (8k miles ago) and now need to replace the rears
I would like to go with a slotted look (really just for appearance)
Would there be any problem changing out the Brembros also for a slotted rotor or do I need to change out the pads for proper functionality?
Old Jan 27, 2008 | 07:32 PM
toddtce's Avatar
toddtce
Changing pads or rotor as one does not require you change the other.
Old Jan 27, 2008 | 09:00 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
You can use whatever pads front or rear with any stock sized rotor whether slotted or not.
Yes, slotted is mostly for looks. Take your pick. Zinc plated rotors might look a bit better with less rust until the finish wears off either with time or with heat from use.
I assume you mean you are changing rotors in the back for slotted and want slotted rotors for the fronts too which is fine.
If the front ferodo pads are not too worn then you can keep them, just clean them off well.
Old Jan 28, 2008 | 08:36 AM
D3m0N's Avatar
D3m0N
Anyone ever heard of http://www.sportbrakes.com there prices seem low they use Brembro blanks front and Zimmermann rear and machine them how you like.
I am thinking slotted and dimpled but really dont know. They have some good comments out on the web but $220 for a complete set seems way too good to be true.
W0TM8
Dec 19, 2019 07:50 AM
thebordella
Aug 31, 2015 01:37 PM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
nomar116
Aug 10, 2015 11:24 PM
