Changing brake pads - need to prepare/turn rotors?
Old Jul 16, 2003 | 08:06 AM
Mjolnir's Avatar
Mjolnir
Thinking of puttin' on a set of dem der Ferodos but a couple of people have indicated it may not be the best idea without preparing the rotors.
Thoughts?
-Jim
Old Jul 16, 2003 | 08:43 AM
Alex@tirerack's Avatar
Alex@tirerack
Turn them, it allows bedding in of a new friction material, and building up of a transfer film to occur much quicker. This factor contribute to smooth quiet and predictable braking. Not resurfacing the rotors will still allow the film to be made, it just takes longer, and can be less audibly pleasing.
Alex
Old Jul 16, 2003 | 09:24 AM
Mjolnir's Avatar
Mjolnir
>>Alex
Thanks Alex,
So does Turning = Resurfacing?
Old Jul 16, 2003 | 09:40 AM
Alex@tirerack
You are correct!
Alex
Old Jul 16, 2003 | 11:21 AM
Mjolnir's Avatar
Mjolnir
So I can do that with a sanding block and 150 grit, right?
Kidding...
Thanks for the help.
-Jim
Old Jul 16, 2003 | 11:50 AM
Alex@tirerack
closer to 250-300 wet dry will cut the glaze just fine. If your rotor's surface is still totally smooth you can do this. If it had ridges and lines, I would have it cut by a machien shop.
Alex
W0TM8
Dec 19, 2019 07:50 AM
gmonde
Sep 8, 2015 06:37 AM
Beau B
12
Aug 24, 2015 01:50 PM
