R50/53 Release cable to make seat slide forward
Old Jan 22, 2008 | 11:58 AM
ECBerg's Avatar
ECBerg
Just as soon as my warranty ran out, both my passenger and driver's side seats stopped sliding forward. Driver's side had slipped off the stop (easy fix), but passenger side had a broken release cable (cable is exposed to kicking by back-seat passengers). When I went to the dealer to get a new cable, I found out the only way Mini sells it is as part of the rail assembly $198! That's a bit rich for me....any idea where I might be able to get the cable without the rails?
Old Jan 22, 2008 | 02:18 PM
tom_evans's Avatar
tom_evans
I would try ebay and if that fails, google it. Then there's always your local junk yard, but that should be your last resort.
Old Jan 22, 2008 | 10:27 PM
chaseabryant's Avatar
chaseabryant
uh oh. I hadn't had time to do so, but I was planning on taking my passenger seat apart to find out why it no longer slides forward to let passengers out of the back. Looks like I am going to be in a little more cash than I thought...
-Chase
Old Jan 23, 2008 | 06:39 AM
ECBerg's Avatar
ECBerg
Issue with seat sliding forward
-Chase
Chase,
You may be allright. The litmus check is to pull on the cable where it attaches to the seat-back on the lower left-hand corner (seen from the back seat) of the passenger seat. Unless it's taught, it's most likely broken. However, if it appears to be intact checK where the cable enters the sleave, the sleave should be seated in a u-shaped slot acting as an anchor for the pulling action when the seat folds forward. If the cable has popped out of the slot, simply pop it back in and you're back in business.
-Eric
Getrieben
Sep 12, 2024 07:03 AM
flyers47
Jul 27, 2020 02:38 PM
theblackfalcon
Oct 11, 2015 09:49 AM
Zettinger
Aug 25, 2015 04:04 PM
