R56 R56 Oil Analysis Back Woo Hooo!
Old Jan 16, 2008 | 01:28 PM
johne123's Avatar
johne123
Just got the report by email. I didn't realize HOPenn (division of Caterpiller) doesn't test for fuel dilution or Total Base Number.
Assuming the Mini 5w30 oil is the same as BMW, then the starting viscosity (cst @100C) is 12.2 according to this.
http://www.bmwe36blog.com/2007/04/22...or-my-bmw-e36/
According to HOPenn, my oil at 5247 miles is at 9.8. Still a 30 weight oil, but viscosity has dropped. Below are the rest of the details. I expected high wear metals, it's a new engine. Otherwise I don't know what to make of this as it's my first oil analysis.
CURRENT SAMPLECustomerJOHN E
Serial No
07 MINI COOPER
Unit No
COOPER
ModelMINI COOPER
MakeBMW
Oil Type
CASTROL
Oil Grade5W30
CompartmentGAS ENGINE
Lab No0801160155
Sample Date12/30/2007
EvalB
CU 49
Fe 69
Cr 1
Al 81
Pb 2
Sn 0
Mo 507
Si 66
Na 20
K 6
Ca 2199
Mg 1314
Zn 1742
B 48
P 1488
Ag 2
Ba 1
Ni 1
CD 0
Ti 0
V 0
Mn 14
Water Negative
Antifreeze Negative
Viscosity 9.8
COMMENTSLab NoEvalComment 0801160155BThe wear metals are elevated. This may be due to break-in wear. More sample are needed to establish a trend. Suggest changing oil and filter(s) if not all ready done. Resample at half of the normal drain interval.
Old Jan 16, 2008 | 01:46 PM
andyde's Avatar
andyde
Interesting that you posted this. I am currently at 7000 miles and getting ready to change my oil for the first time. When I called to schedule the appointment, they almost turned me down stating that it was completely unnecessary... I am going in this Saturday.
Old Jan 16, 2008 | 01:48 PM
Modnar's Avatar
Modnar
They're charging you for it though, right?
Old Jan 16, 2008 | 01:57 PM
ignote's Avatar
ignote
I don't think this is very good. Iron, Copper, Aluminum, and Silicon (Dirt) are way high. Are you running an after market air filter? If so, get it out of there.
I suggest you change the oil and get a sample analyzed after 3000 miles.
Better yet. Post these results over at the http://www.bobistheoilguy.com forums and see what those folks think.
Serial No
07 MINI COOPER
Unit No
COOPER
ModelMINI COOPER
MakeBMW
Oil Type
CASTROL
Oil Grade5W30
Lab No0801160155
EvalB
CU 49
Fe 69
Cr 1
Al 81
Pb 2
Sn 0
Mo 507
Si 66
Na 20
K 6
Ca 2199
Mg 1314
Zn 1742
B 48
P 1488
Ag 2
Ba 1
Ni 1
CD 0
Ti 0
V 0
Mn 14
Water Negative
Antifreeze Negative
Viscosity 9.8
Old Jan 16, 2008 | 02:07 PM
johne123's Avatar
johne123
They're way high because the engine only has 5200 miles on it. If I didn't mention that, sorry. This is still the break in period. Already posted to BITOG.
Old Jan 16, 2008 | 02:19 PM
andyde's Avatar
andyde
Well, the lady that called me to confirm the appointment said no charge. I know better that when I show up this Saturday; I'll be hit with a the charge.
Old Jan 16, 2008 | 02:35 PM
Robin Casady's Avatar
Robin Casady
Thanks for posting the results. My take on it is that an early "break-in" oil change is a good idea, not a waste of resources. I wouldn't want to drive another 10,000 miles on that oil.
Old Jan 16, 2008 | 02:39 PM
johne123's Avatar
johne123
For anyone interested, here's a virgin oil analysis on BMW 5w30:
http://www.bobistheoilguy.com/forums...rue#Post478676
Aluminum 0
Chromium 0
Iron 1
Copper 0
Lead 0
Tin 0
Molybdenum 92
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 0
Boron 76
Silicon 8
Sodium 2
Calcium 2692
Magnesium 10
Phosphorus 745
Zinc 841
Barium 0
SUS @ 212 66.8
Flashpoint 455
Fuel -
Antifreeze -
water 0.0
Insolubles trace
SUS viscosity looks to be about 12 measured as cst
Old Jan 16, 2008 | 03:58 PM
dirkinoff's Avatar
dirkinoff
GREAT INFO! Thanks.
Old Jan 16, 2008 | 04:09 PM
daffodildeb's Avatar
daffodildeb
Hah! If you talked to Denise, she doesn't know squat. Prepare for about $80. I think that's what Heather quoted me. And I know they won't do it for free, not until you reach that mythical number on your computer (which seems to change daily, ever out of reach), or one year. I'll be going in sometime in February. I've changed twice since new, but I have a nice Hubby at home to do it! Currently at 15,000+ with a February 21 birthday.
Old Jan 16, 2008 | 04:10 PM
johne123's Avatar
johne123
Here's the thread at BITOG:
http://www.bobistheoilguy.com/forums...62#Post1066062
I haven't had anyone chime in yet if the drop in viscosity is indicative of excessive fuel dilution or not.
Old Jan 16, 2008 | 04:43 PM
smackboy1's Avatar
smackboy1
I'm no tribologist but I did stay at a Holiday Inn Express last night so here goes nothing:
Fe 69 expected from break in
Si 66 is the air filter dirty? Maybe time for a change.
Al 81 seems a little high, maybe piston wear?
It looks like the factory oil is on the thick end of SAE 30 and sheared/diluted down to the thinner end of SAE 30. I think SAE 30 is 9.3-12.5 at 100 C. GC is pretty thick too, I wonder if the formulation is similar.
This is a direct injection engine so fuel dilution is the $64 question. If let run to out to BMW recommended 15K miles, I wonder if it would be down to a 20 weight oil. I would also curious to see the TAN and TBN to see how much acid protection was left in this oil.
For your next UOA, try using a lab which offers more details e.g. Dyson Analysis.
Old Jan 16, 2008 | 10:04 PM
johne123's Avatar
johne123
Al 81 seems a little high, maybe piston wear?.
The entire car only has 5200 miles on it (6300 now). I highly doubt the air filter is dirty. It's more than likely leaching from gasket materials. Aluminum would likely be from cam journals in the head wearing in.
Old Jan 17, 2008 | 04:14 AM
smackboy1's Avatar
smackboy1
I don't disagree, could be all that. Can't draw any real conclusions until there's more UOA data to see a trend. Are you planning on keeping the oil or changing the oil?
Our MINI, I changed out the OEM oil at about 1,500 miles (no UOA). I am awaiting the UOA for the 2nd fill now that the car has 7K on the odo. I'll post it when I get it.
Does anyone have a UOA for the OEM oil at higher mileage with TBN, TAN and fuel dilution data? That would be interesting.
Old Jan 17, 2008 | 05:30 AM
minibayb's Avatar
minibayb
While no expert either I do look at oil samples and data and in my line of work we do hundreds of oil samples a month albeit on diesel engines. I would agree that more data needs to be acquired in order to look at trends to determine what is going on. I would also agree that the copper, iron and alum seem high but I would think that most of the higher numbers would be attributable to engine break in, not uncommon from what we see in a new or newly rebuilt engine. The number which worries me would be the silica or dirt entry. We think that anything 10 or above is bad and we start looking for reasons/causes and fix. There again diesel specs may be different than these engines.
Old Jan 17, 2008 | 08:41 AM
johne123's Avatar
johne123
I'll be changing the oil as soon as I get the filters I just ordered. If it's not too cold this weekend, I might buy one filter from my local dealer and do it then. I'm not sold on the whole changing oil early thing in modern engines and haven't yet seen conclusive data that shows it's needed. From oil analysis I've seen engine break-in lasts for several 10's of thousands of miles so any benefit of doing the first change extra early doesn't seem as important unless you're going to change your oil every 1000 miles for the first 30k miles.
Old Jan 26, 2008 | 07:17 AM
richard612's Avatar
richard612
The high Si is from leftover sand from the engine casting process. It's way way way too early to start having concerns about the health of the engine. Just chalk it up to "interesting" and do an oil change.
Si will probably remain elevated for quite some time.
Old Jan 26, 2008 | 04:23 PM
scottab36's Avatar
scottab36
I am at 13,000 miles after just under four months of ownership. I have already changed my oil twice. It just makes me feel better to do that. The MCS says I still have 6,000 miles left before changing the oil. I can't see going almost 20,000 miles on the original oil delivered with the MCS.
Old Jan 27, 2008 | 07:39 AM
graphicjoe's Avatar
graphicjoe
The numbers are meaningless to me because I don't know what the values should be. Does the analysis provide a set of "normal" values, or some kind of guideline as to what the various values should be and what it means if they are out of range?
cheers,
Joe
Old Jan 27, 2008 | 08:24 AM
kevinminict's Avatar
kevinminict
I am at 11,500 Miles. No change light yet ........I'm hoping soon.
I have had my MINI since end of July 2007.
Old Jan 27, 2008 | 10:03 AM
EENY's Avatar
EENY
Originally Posted by kevinminict
I am at 11,500 Miles. No change light yet.
Look at the mileage in the OBC just as you turn on the car - the number stays on screen for just a few seconds. This indicates when your call will turn the service light on. It is set to a very long period, so don't be surprised if you still are a long way off. That's why many of us changed the oil anyway, not feeling comfortable to wait for maybe 20-25K miles, give or take.
Old Jan 27, 2008 | 10:11 AM
johne123's Avatar
johne123
cheers,
Joe
Good question. Once an engine is broken in, the wear metals (Fe, Al, Pb, Cu, and Cr) should be around 10ppm or lower. Si usually indicated dirt getting into an engine past the air filter. Solubles indicate the oil filter is no longer doing its job. Then there is the data on the status of the oil itself: viscosity, amount of Zn, and P, along with TBN and a few others this lab didn't test.
I was mainly looking for excessive fuel thinning the oil out since this seems to be happening with some direct injection audi engines.
As for a guide, Blackstone provides averages of tests they've run on that same engine for yours and other customers. The lab I used doesn't do this. If you check out bitog.org you'll find lots of people who know what and can comment on what these numbers mean.
Old Jan 27, 2008 | 06:10 PM
bdr127's Avatar
bdr127
How long has BMW been using synthetic oil in their vehicles? 10 years? 15 years?
I'm not a chemical or mechanical engineer, but I'm going to go with what the BMW/MINI engineers have designed and recommended.
I can't possibly see them recommending something that will just destroy the engine. Between the warranty claims and bad PR, why would they risk it?
Old Jan 27, 2008 | 09:13 PM
Robin Casady
A decision like this is a cost-benefit decision based on benefit to the corporation. The interests of the corporation may not be completely in line with the interests of the car owner. They have marketing and cost considerations that are different than ours
They want their cars to appeal to new buyers. The longer they can provide free maintenance, the more appealing to buyers. The farther they can space the maintenance periods, the lower the cost of that selling point. Having long oil change intervals also is a good selling point. The up-market buyer sees it as less hassle for upkeep. So, they might be willing to trade increased engine wear to reap those benefits.
If you turn over a car every two or three years, engine wear might not be an issue for you. It becomes the problem of the next owner. I bought my previous car in 1990 and still have it. For someone who puts over 100K miles on a car, engine wear might be more important than it is to BMW.
I don't know what decisions are made at BMW concerning this issue, but I do think that they a different perspective than a car owner.
Old Jan 28, 2008 | 06:50 AM
rockridge's Avatar
rockridge
Excellent discussion.
Anyone have a similar test result, but with an after market Cold Air Intake? Such as Alta?
