Can you use a 15 inch tire as a spare when other tires are 16 in?
Old Jan 8, 2008 | 07:36 AM
kraigster414's Avatar
kraigster414
Forgive my ingorance. I have no spare tire since my car (2005S) came with run flats. I now have non-run flats so I am looking for a donut or a regular tire in the event of a blow out.
Old Jan 8, 2008 | 08:34 AM
Partsman's Avatar
Partsman
Legion_of_Doom
If you keep the outside diameter of the 15" spare close to that of the 16", you should be fine.
Old Jan 8, 2008 | 08:37 AM
jakay11's Avatar
jakay11
a follow-up question:
will a 15" rim clear the standard S brakes (non-JCW)?
tdm156's Avatar
tdm156
Ruling the curves
I think the spare on my 06 MC is a 15" but I could be wrong. Partsman is right though so long as its close it will be fine.....just dont leave it on there for an extended period as that is why its called a "spare"....not for extended use.
Old Jan 8, 2008 | 08:49 AM
Partsman's Avatar
Partsman
Legion_of_Doom
I know the stock 15" Holies will fit, other than that, don't know.
Old Jan 9, 2008 | 03:58 AM
Dead Skunk's Avatar
Dead Skunk
15s
I run 15 inch wheels with my snows on a 2003 MCS. I've tried on 3 different sets that I have for my miata and they'll all fit .
Old Jan 9, 2008 | 05:49 AM
cube17576's Avatar
cube17576
Coordinator :: STLMini
If you have a flat on the front, you can always put the spare on the back and move a regular wheel to the front.
Old Jan 9, 2008 | 07:53 AM
Dan00Hawk's Avatar
Dan00Hawk
The standard 15" wheels will clear the S brakes on the non-R56 cars. Mine for example:
Like Partsman mentioned, the overall diameter of the tire is what needs to be close to stock, not the wheel diameter. A 15" wheel with 175/65/15 will have nearly the same overall diameter as a 16" wheel with 205/50/16.
Old Jan 9, 2008 | 11:58 AM
JCWGrover's Avatar
JCWGrover
A good rule to remember, if you have an odd sized wheel for a spare, is to put it on the rear for a FWD car
Old Jan 9, 2008 | 12:14 PM
agranger's Avatar
agranger
Will a 15" wheel fit our brakes? The answer is 'maybe'. It depends on the shape and offset of the wheel. As someone mentioned above, the 15" will fit more easily on the back wheels (smaller brakes), so if it won't fit the front when you have a front blow out, put the 15" on the back and move a good back wheel to the front.
Waszak
Oct 21, 2017 05:55 PM
broncobuddha
Suspension
Sep 18, 2015 05:16 PM
Ntety
Sep 2, 2015 08:39 PM
