Suspension Is the front sway bar a good idea?
Old Jan 3, 2008 | 05:13 PM
drsilvermini's Avatar
drsilvermini
I WAS going to put a 27mm front sway bar on my MCS but a bunch of people have been telling me that it is a bad idea to do. Any ideas?
Old Jan 3, 2008 | 05:26 PM
glnr13's Avatar
glnr13
27mm front with a 19mm rear? sounds like a recipe for understeer
Old Jan 3, 2008 | 07:36 PM
minibeel's Avatar
minibeel
Coordinator :: PDX MINI
You can do it. But, have enough money and time available to upgrade something else if you don't like the result (could be a bit of understeer).
Only one way to find out...
dan
Old Jan 3, 2008 | 08:19 PM
Ryephile's Avatar
Ryephile
A 27mm front bar would be a disaster no matter what rear bar you have. Understeer heaven!
I have an H-Sport front anti-roll bar [26mm equivalent] on my MCS on full soft along with an H-Sport Comp rear anti-roll bar [22mm equivalent] on full stiff and even with tuned coilovers the car will eventually understeer on slow corners. I like my car to be very stable in high speed sweepers [or be neutral with R-compounds] so that's how my car is setup; it'd pretty much get pwned at an autocross.
Short story shorter; stay with the stock front bar and get a 3-way adjustable 21mm rear ARB; that'll let you dial in the handling perfectly.
silence2-38554
Nov 12, 2015 09:39 AM
minipopkart
Aug 13, 2015 05:22 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
