R56 Tire Pressure Monitor Cold Natured?
Old Jan 2, 2008 | 11:02 AM
terrytrucker's Avatar
terrytrucker
Hey. Is it possible for the tire pressure monitoring system to give a false reading when it is extremely cold outside?
Old Jan 2, 2008 | 11:05 AM
johne123's Avatar
johne123
Anything's possible, but it's more likely your tires are at a lower pressure due to the low temperature. This happened to me yesterday with it being 15F outside. When I checked them this morning, sure enough, my tire pressures were about 20% down at 30 psi. IIRC, 20% drop from when they were calibrated is what the system reports on.
Old Jan 2, 2008 | 11:07 AM
terrytrucker
I figured that was the case, but I wasn't sure if maybe the system hates cold weather and reads falsely. The system worked great when I actually got a flat, so when it came on again, i had a sinking feeling! I was dreading changing a flat in 9degrees weather! BUt i got out and everything was fine, no hissing or anything.
Old Jan 2, 2008 | 11:17 AM
Robin Casady's Avatar
Robin Casady
Did you manually check the pressures? They may have dropped to dangerous levels just from the cold.
Old Jan 2, 2008 | 11:24 AM
terrytrucker
i am doing it after work. It was not safe to do it at the time. Thanks for the wonderful advice. Everyone is so helpful.
Old Jan 2, 2008 | 12:37 PM
jakay11's Avatar
jakay11
cold weather also exacerbates slow leaks...
but if you want to see what cold can do to tire pressures with no leaks, get a balloon and fill it inside (either air or helium, doesn't matter)
take it outside for 5-10 min and watch it "deflate"
bring said balloon inside and watch it "re-inflate" as the air warms back up...
HTH.
Old Jan 2, 2008 | 08:46 PM
ladisney's Avatar
ladisney
The manual says that snow and/or cold can cause false reads. The snow sets mine off everytime. R56 Aug07 build.
Old Jan 2, 2008 | 09:36 PM
Charlie Croker's Avatar
Charlie Croker
Funny this thread pops up at this time in my life. I was just down at the Texas coast for a winter retreat and my TPMS kicks in and tells me that I have a tire problem 200 miles from home on a sunday.
Fortunately, I had my trusty portable tire pump and tire guage in tow with me, (since I had no spare) and reinflated the tire enough to get me home. After very close inspection, I found a 3" all weather screw imbedded deeply into my new tire. This threw a "check tire" signal. I reinflated and reset the code and had no reoccurance for the rest of the trip home.
This past evening, the temp went down below 25 and when I woke up, the tire was as flat as a pancake. Again, I reinflated and went to work. After work, spent 3 hours at discount tire having the tire fixed and tires rotated.
THe cold really seemed to increase the shrinkage of the tire.
Old Jan 2, 2008 | 09:50 PM
terrytrucker
I added more air to those bad boys and reset the monitor and the light has not come back on.
TREX
Nov 2, 2019 07:31 PM
LordOfTheFlies
Oct 19, 2015 05:02 PM
TJANK
Aug 24, 2015 06:11 PM
nomar116
Aug 9, 2015 09:42 AM
