Cup holder "From Hell"
Old Dec 26, 2007 | 05:57 PM
harley0711's Avatar
harley0711
OK - am I the only one that is frustrated the front cup holder - this is Not rocket science here - however, when trying to put a soda can in - it is so tight that it is tough to pull out - don't want to pull to hard for fear it will come out and I will soak my interior - lol.. short of cutting off those annoying little tabs - anyone got any suggestions... :impatient
Old Dec 26, 2007 | 06:02 PM
Shellbell's Avatar
Shellbell
?????? huh? What year is your car? Are you talking about the lower ones where there are 2 holders?
Old Dec 26, 2007 | 06:06 PM
4xAAA's Avatar
4xAAA
Suggestion:
Immediately after purchasing said soft drink, turn to the arm candy seated on the right and say
"Here, hold this a sec"
MOTOR ON!
Old Dec 26, 2007 | 06:10 PM
F13rc3dr4g0n's Avatar
F13rc3dr4g0n
Not short, fun size!
mom wound up breaking the rim and its rubber holders holder right off of hers... i wound soaking my seats... but i found a solution to prevent this in the future... if you will take a napkin and place it in the holder and allow it to cover the rubber pieces, you will be able to put a drink in and pull it out with no problem and the grip is still good enough that they won't fall out on a turn
Old Dec 26, 2007 | 06:33 PM
Pav's Avatar
Pav
Try working in the rubber pieces. I have a 0.6L SIGG ... it fits perfectly. Leave it in there for a day or two to work in the rubber, and you'll be all set.
It beats cutting them right off.
chxpla2's Avatar
chxpla2
Most have said that the grip loosens up over time, I was frustrated with mine as well, then one day the tabs stayed down and all was good. Try leaving a water bottle in them for a couple of days, I thinks that is what did it for mine, it was also summer and hot out, so that may have helped to keep them down as well.
Msteadman's Avatar
Msteadman
That cup holder really is evil... Good thing there is no drinking, especially soft drinks, allowed in my MINI.
Old Dec 26, 2007 | 06:38 PM
Charlie Croker's Avatar
Charlie Croker
Has anyone thought of using some strong adhesive applied to the under side of the tabs, then put a cup/bottle in the holder to keep the tabs against the sides?
Once it sets, the tabs should stay down in this position.
Old Dec 26, 2007 | 06:41 PM
Tomasthanes's Avatar
Tomasthanes
We just don't drink sodas... We drink XS (Energy) Drink from Quixtar. The cans are small enough to perfectly fit in those lower cup holders... Probably coincidence rather than fore-planning.
Old Dec 26, 2007 | 07:16 PM
Sowellman's Avatar
Sowellman
I used the ashtray/coin holder to loosen up both of the front drink holders. The suggestion about leaving a water bottle in there for a few days is also a good idea.
Old Dec 26, 2007 | 07:38 PM
harley0711's Avatar
harley0711
LOL - glad to hear others are feeling the same....
I will try leaving a can or as suggested - the ash tray ...
Old Dec 26, 2007 | 07:40 PM
ashboomstick's Avatar
ashboomstick
Or you could do something as ridiculously simple as rotate the drink clockwise (or even counterclockwise) as you pull up...
Old Dec 27, 2007 | 09:07 AM
miniemee's Avatar
miniemee
+1 on all comments. A totally badly designed set of cup holders. The rubber and chrome on mine came out and I had to reglue. They dont do a good job holding things in place and you have to be very careful to rotate the drink to take it out of the cup holder correctly. In addition, with a drink in place, it blocks access to the lower control switches. The Honda Civic I had was much better, but it is the only thing better on the Civic.
Old Dec 27, 2007 | 09:12 AM
Minidrivr's Avatar
Minidrivr
I'm with you on that one.
Old Dec 27, 2007 | 09:14 AM
R56 Ed's Avatar
R56 Ed
First thing I did was to gently pull out the tabbed ring, and reinstall the retainer ring at the top. Works perfectly, the price is right (free), and no more chance of spilled drinks.
Old Dec 27, 2007 | 09:26 AM
rosmakloma's Avatar
rosmakloma
....don't drink and drive - problem solved
Old Dec 27, 2007 | 09:45 AM
Loony2N's Avatar
Loony2N
Leave a can in the cupholder for about a week and the tabs stay down. Or get a really long straw.
Old Dec 27, 2007 | 12:41 PM
scabpicker's Avatar
scabpicker
I know this section is a forum for stock problems and issues, but I like the chinese handcuff cupholders. As is mentioned earlier, most things, even styrofoam cups will come out when you twist them back and forth. Their tightness ensures that I am not gonna take a surprise bath in the middle of a turn.
I used to think that my old p/u had the best cupholders anywhere, they would hold any size drink, from a thimble to a bucket. They weren't the greatest at actually holding the drink, though. A heavy pot hole would knock the drink out if the truck had no load (it was a 3/4 ton truck, bouncy). Plus, the pair eventually just broke off of the dashboard, probably due to the size of the drinks it was usually asked to carry. (well, they made it big enough to hold the 72oz....)
Really, it seems like this is not an actual defect. Maybe a problem, if you are looking for one. C'mon, holding your drink in such a small, capable car is not an easy problem to solve.
Old Dec 27, 2007 | 12:45 PM
Loony2N's Avatar
Loony2N
Tooth be trolled, I have had more instances of drink leaping out of the thermos through the drinking hole, due to the "go-cart ride" than splashes caused by getting the drink out of the holder. But, it usually is entertainment to someone watching me trying to get the cup-holder to unleash a 12 oz. soda can.
Old Dec 27, 2007 | 12:55 PM
terrytrucker's Avatar
terrytrucker
I love my car, but LOATHE the cup holders!
Old Dec 27, 2007 | 01:52 PM
Reverend Heat's Avatar
Reverend Heat
I have to watch for coffee coming out of the drink hole lid. The sport suspension will bounce the coffee out if it is more than half full.
Old Dec 27, 2007 | 02:46 PM
Birdman's Avatar
Birdman
How did you get the rim off? I looked at that once, and it seems to be all one piece, is there a hidden set screw somewhere or something?
Minidrivr's Avatar
Minidrivr
Where did that thread go with the story of a large cup tipping over as the cup holder came apart, dumping it's contents all over the passenger floor?
Old Dec 27, 2007 | 03:29 PM
lacning74's Avatar
lacning74
Mine kept coming off with my drinks. The platic ring and rubber piece are separate. I had the dealer put it back snugly. Hasn't come off since.
Old Dec 27, 2007 | 04:07 PM
R56 Ed's Avatar
R56 Ed
I just grabbed one of the rubber tabs in the holder and gave it a good solid tug upwards. As it came loose it also pulled the retaining ring out at the same time. Simple enough to reinstall the ring by pushing it back into place and it looks perfect. I'm not aware of any mechanical screws or clips holding the thing together, just friction.
I honestly didn't know what would happen when I yanked on the rubber tab, and this time I got lucky. This time
Don't know if it matters, but this was on an '07 Cooper (non S) hardtop. There might be some difference in earlier cup holders, but I can't imagine they'd be any more hateful
