R50/53 Continuing Oil Leak
Old Dec 25, 2007 | 07:52 PM
22CooperS's Avatar
22CooperS
Continuing Oil Leak
I have a 2003 Cooper S with just over 30K miles on it. I was experiencing an oil leak after having my coolant and oil replaced by a technician at the dealership I work at (non-MINI dealer, tech has worked on MINI's before).
The technician concluded the issue was the oil cooler. The oil filter, plug, and gasket are dry, and the only leak can be found coming from the oil cooler. So, last week he replaced the 2 O-rings in the oil cooler. He said the existing O-rings were a bit crusty and cracked, and were likely the issue.
Unfortunately, I pulled into my driveway tonight to notice two oil spots about 4 inches in diameter- the issue appears to have not been fixed yet. I haven't crawled underneath yet to check it out... any ideas or input??
Old Dec 25, 2007 | 09:59 PM
donjulio's Avatar
donjulio
Did the technician used dyes to determine where the oil was leaking from?
Use a chalk to mark where your car was parked and determine where it was in ur engine bay. I used this method to find that my filter was leaky.
Old Dec 25, 2007 | 10:16 PM
Minidrivr's Avatar
Minidrivr
It could also be oil left over from the leak if the tech didn't clean up any place where oil might have run to while it was leaking.
Old Dec 26, 2007 | 07:29 AM
22CooperS's Avatar
22CooperS
From what I've seen technicians at my dealership do, the usually spray down anything they worked on with a cleaner to avoid problems like the appearance of fluids leaking, etc.
We have narrowed the problem down to the oil cooler (or so we think!)... anything else that it could be?
woodstudio
Mar 15, 2020 08:28 AM
SheldonCooperS
Aug 25, 2015 11:57 AM
ShadyCoop
Aug 24, 2015 06:05 AM
Laura Redd Casler
Aug 15, 2015 09:32 PM
azntaiji
Aug 13, 2015 03:24 PM
