R50/53 Brake Light Died
Old Dec 25, 2007 | 01:47 PM
6f7's Avatar
6f7
Brake Light Died
It's been a long time since posting....
I have an 02 MINI that has a right tail light that stopped working this week. I had done the rear fog mod in 03. Heres everything I tried.
1. Right rear fog blown & replaced bulbs (brake and rear fog)
2. With headlights on and all running light are fine
3. Swapped left and right bulbs
4. Swapped left and right bulb clusters (circuit boards) and still only the left works!
5. checked that fog jumper was securely soldered still
Is there a separate fuse for the left and right brake lights?
Is it potentially a bad relay somewhere?
Is the wire grounding somewhere after all these years?
Help. This is driving me nuts!
Old Dec 25, 2007 | 08:51 PM
savage's Avatar
savage
my right side brakelight went out as well... not sure if it was today or not, didnt look into nearly as deep as you did but i think ill check before i go out and buy a new light and realize i wasted money
Old Dec 26, 2007 | 04:53 AM
cristo's Avatar
cristo
Alliance Member
Isn't a break light, by definition, broken?
Old Dec 26, 2007 | 10:40 AM
savage's Avatar
savage
yea problem is thats not how they spell it.
Old Dec 26, 2007 | 11:07 AM
6f7's Avatar
6f7
Precisely.
Old Dec 26, 2007 | 11:41 AM
cristo's Avatar
cristo
Alliance Member
Originally Posted by 6f7
Break Light Died
Yep.
Old Dec 27, 2007 | 08:02 PM
wvphoto's Avatar
wvphoto
my brake light broke, i don't get a break
Old Dec 27, 2007 | 08:05 PM
savage's Avatar
savage
so i found out what happned to mine... it actually broke. like the 'dome' broke off. like 2 pieces of a light bulb...it was neat. i got 2 new bulbs for like 3 dollars. sweet.
Old Dec 27, 2007 | 08:06 PM
penguinpwrdbox's Avatar
penguinpwrdbox
I break for brakes.
Old Dec 28, 2007 | 08:41 PM
6f7's Avatar
6f7
Thanks for all the 'break' comments, since my spelling is my biggest concern.
Thanks GBMINI! who helped on MINI2 by mentioning that a few people that had the BCM fail. After a few searches it looks like a problem. Aargh. Now I just need a way to confirm its the BCM. hmmm... any ideas?
Old Mar 13, 2008 | 07:00 PM
gwolfe's Avatar
gwolfe
I have just encountered the same issue - the local garage says it is the Body Control Module (BCM?)...did you finally determine what caused your issue and if it is the BCM - what did that set you back?
Old Mar 13, 2008 | 08:28 PM
resmini's Avatar
resmini
I sorta remember this being talked about. It's the expensive "brain" for all the lights. If you did the brake light mod and the dealer knows it, no warranty repair.....so I've heard. The extra bulb overloads the brake light circuit according to them. I put an LED lbulb in the fog light spot for my brake light mod. It only uses about 1/10 as much current...and it looks neat.
Old Mar 14, 2008 | 02:21 AM
DaveTinNY's Avatar
DaveTinNY
Their brake lights changed to brake lites. There are brake lites that look like break lights... They're all very confused now. ;-)
I like lunch breaks. It's Friday.
Old Aug 2, 2009 | 06:52 PM
mogsxr750's Avatar
mogsxr750
I believe I have encountered the same issue, due to the Diode mod. Can anyone tell me where the BCM is located? I would like to verify that this is the root of my problem. I swapped tail-light "boards" and the problem stays in the right rear. I figured it's either the BCM or an actual problem.
Does anyone know if the the BCM has enough internal impedence to prevent any further damage if I where to just run a jumper wire from the left tail light to the right?
Old Jul 29, 2011 | 04:32 PM
Neufusion's Avatar
Neufusion
Bump. I'm about to try the same thing. Will it work or fry the other side of the BCM as well?
I suppose I could use 2 LED bulbs, but LEDs are very dim. Maybe the current of 4 LEDs is still less than 1 incandescent.
scottrn
Aug 22, 2015 07:26 PM
Terry Gallentine
Aug 11, 2015 03:31 PM
