Drivetrain Alta Intake sound
Just got mine on tuesday, installed yesterday. W - O-O- W! I love the sound of this thing. The whine and the suck/pop when you hit the gas is awesome. I think more power too... no, definetly more power.
Thanx Randy!
PS. One screw-up on Alta's otherwise well thought-out product is the metal pipe to which the filter attaches is too short, so the filter slips as you tighten the ring. I had to flare it out with a pair of pliers and then attatch the filter. Much better...
Motor On!
Thanx Randy!
Motor On!
Same here I put mine on last week. The instruc say to degrease the lip of the filter. I did that and put a piece of electrical tape around the metal piece too.
But I agree it should be a little bigger for a better grip
Mike
Mike
I got mine from randy last week to. Tha sound is great and loud, I have the pulley done by Randy and the magnaflow exhust. Th cooper s is very fast and you canhear the whine on the sc. when you take off.
Thank you Randy, and let me know when the Blue Tube for the intake comes.
cooper s pulley, alta intake, mgnaflow exhaust,lapiz blu, pack1, pack2, rv 90 wheels, Hella Rally Lights and working on headers and throtle body.
my cars: http://www.msnusers.com/ppanther
The stripes you will see are the test ones and are plastic so they are not perfect and install them to have an idea how thw car will look.
Cooper s 2003
mustang 65 shelby clone 289 hipo 4 speed air dam etc etc.
Cooper s 2003
I should be getting my ALTA intake tomorrow, it shipped from Randy's this Monday. I'm geeked to hear and feel the differences between it and my current Madness intake. Thanks for the heads-up on the filter tube needing extra help.
Cheers,
Ryan
Cheers,
Ryan
>>So, what's the verdict on intakes. Hearing lots of good things about Mini-Madness and Alta. Any thoughts ??
>>Spike
Follow on to my question. I'm hearing that most of you who have upgraded your intakes have enjoyed the great sound produced by the SC. With the pulley reduction and the intake upgrade, is the higher engine noise acceptable for longer drives (ie: does it get annoying after a while?).
Spike
>>Spike
Spike
Spike, when you're cruising at steady-state (aka highway) you don't hear the supercharger whine or intake noise at all. This is because they are under very little load, and therefore don't make much sound.
I have the pulley, ECU, and Madness intake (right now), and highway cruising is identical to stock. ....but once you step on it...
Cheers,
Ryan
Cheers,
Ryan
Hey Ryephile,
Thanks for your thoughts. One more question if I might. When I do get my Blue Screamer, I will definitely do the Pulley, ECU, and Intake, as you've done. What if any decrease in mileage have you noticed?
Spike
Spike
I also had the problem of the filter slipping off when tightening the clamp. Went over to the hardware store and bought a Degreaser (like the instructions said to) and then it went on fine.
I thought I could get away without it, then tired soap and water, and finally went and bought the degreaser! It works like they said it would.
I agree the sound is great and performance is better. $200 well spent.
Cheers!
Cheers!
Well, I guess I was negligent about updating this thread
One pointer is that you absolutly have to flare the metal tube connecting the filter and throttle body hose. Grab a pair of good pliers and just bend a crude flange into the tube all the way around it and you're good to go. Not doing this will cause the slippery filter and hose to slip off.
ORDER ONE TODAY
Cheers,
Ryan
).One pointer is that you absolutly have to flare the metal tube connecting the filter and throttle body hose. Grab a pair of good pliers and just bend a crude flange into the tube all the way around it and you're good to go. Not doing this will cause the slippery filter and hose to slip off.
ORDER ONE TODAY
Cheers,
Ryan
Okay cool. I trust what you have to say. I asked Randy the same thing and I think I read somewhere that he was leaning towards the Alta also. Thanks for the info about installing also, but Randy is gonna do it so I trust he wont flub it up.
I'm glad you said it is much better than the Madness, because everything else I have read has been like "well it's kind of similar blahblah"
Thanks, and my MF from mftech are great too.
jrezzo
Aug 9, 2015 10:32 PM
