215/35-18 or 225/35-18???
Old Dec 22, 2007 | 08:50 AM
nparker's Avatar
nparker
Need to get some new tires and am considering going to 225/35 from 215/35. I want a little more sidewall height but do not want a 215/40. Anyone running a 225/35? Do you have any rubbing.
I'm running 18 x 7.5 with a 45 offset. Lowered 1.5 inches on Koni coilovers. Front camber -2.0 degrees and back camber -1.5 degrees.
Old Dec 24, 2007 | 08:00 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
215/35-18 fits rims 7-8.5" wide, tire diameter 23.9"
225/35-18 fits rims 7.5-9" wide, tire diameter 24.4"
Should work without rubbing, tire selection slightly different with each size.
You can always go a little more negative camber in the rear if needed or do a little trimming on the plastic wheel arches.
GLN305
Tires, Wheels, & Brakes
May 1, 2012 08:45 PM
DARK CHILI
Aug 24, 2007 10:38 AM
paullees
Sep 23, 2006 10:17 AM
PMC
Feb 20, 2006 06:26 AM
DaKineMINI
May 27, 2003 12:47 PM
