R50/53 Help
Old Dec 14, 2007 | 07:24 PM
Phillip's Avatar
Phillip
Help
My drivers side xenon bulb went out, its broken, where can I get a replacement, reasonably. Thanks.
I just found this site, I think this is what I am looking for, but want to be sure, local dealer told me $215 today, plus would have to order it.
Old Dec 14, 2007 | 08:05 PM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
I have just the bulbs in stock. But it usually is the ignitor unit. Or did hit something and break the lens too? I can get the whole unit if need be.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old Dec 15, 2007 | 07:44 AM
Phillip's Avatar
Phillip
Its just the bulb, lens is in one piece. How much is an ignitor unit?
Old Dec 15, 2007 | 09:32 AM
chpsk8's Avatar
chpsk8
Pelican Parts is a decent resource. The link here is for a 2004. Might want to start at the homepage and drill back in for your year.
http://www.pelicanparts.com/cgi-bin/...=MIN-19224-M97
Just to check... the bulb itself is broken? Have you swapped sides to verify? Generally it's the ballast that goes out and the bulb is fine. You can test the bulb by putting it in the other headlight and see if it fires.
Here's another good resource
http://www.realoem.com/bmw/select.do
You can drill down to your year make and model and then find the specific BMW part number. Good one to bookmark.
Old Dec 15, 2007 | 03:05 PM
Phillip's Avatar
Phillip
I know the bulb is gone, how long are they made to last? I pulled the bulb out, the glass between the two metal pieces, well it split in two parts now. Afraid to pull the other bulb out to swap them, dont want to have two busted bulbs. Went to NAPA at the advice of a fellow MINI driver that works at PEP Boys. Should be in by Thursday next week.
