Scored Rotors
Old Dec 12, 2007 | 07:41 AM
manicrodder's Avatar
manicrodder
Scored Rotors
My 06 has several grooves worn in each front rotor. Brakes work fine with no pulling or noise. Should I be concered with the scoring? Car has only 6100 miles.
Old Dec 13, 2007 | 06:27 PM
bdmini's Avatar
bdmini
How deep are these "grooves"? Is the metal actually scored or are they smooth ruts? If there's no pull or noise or loss in stopping power, it's probably fine. Also, are the grooves uniform in their appearance on both sides?
Later
Old Dec 13, 2007 | 06:46 PM
ScottRiqui's Avatar
ScottRiqui
If it's a bunch of concentric grooves of equal (shallow) depth that look like the grooves on an LP, that's normal.
If there are individual grooves that are much deeper than that (they will look like circles on the rotors), then either you've worn your pads down to the rivets (not likely without the wear sensors warning you), or something hard has gotten wedged between the pad and the rotor.
Old Dec 13, 2007 | 10:24 PM
manicrodder
They do appear uniform and equal on both front rotors. Performance is good and quiet. Guess it is ok. Thanks guys.
FatherG
Oct 3, 2015 05:06 PM
Tires, Wheels & Brakes
Oct 1, 2015 02:22 PM
Oct 1, 2015 12:18 PM
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
