R50/53 Grinding sound when idling
Old Dec 11, 2007 | 06:23 AM
Roeri's Avatar
Roeri
I am experiencing a grinding sound from my engine when idiling. It sounds for all sakes and purposes like the car has no oil in it, although I know it does. I've also just replaced the spark plugs along with an oil change and neither seemed to resolve the issue.
Anyone know what this can be? I am sorry for the vague description but it's all I have, I'm the furthest thing from a mechanic one can be.
Old Dec 11, 2007 | 07:38 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
How many miles are on your car? It might be your supercharger going bad, a few thousand miles or less from destroying itself.
Old Dec 11, 2007 | 07:41 AM
Roeri's Avatar
Roeri
Originally Posted by nabeshin
How many miles are on your car? .
44K.
Oh God I hope not!
Old Dec 11, 2007 | 08:03 AM
guitfiddler's Avatar
guitfiddler
Check my recent post... https://www.northamericanmotoring.co...d.php?t=122502
And this one... https://www.northamericanmotoring.co...ad.php?t=74674
Then go see Eddie at 1fastmini in Winter Park. He's replacing my supercharger right now.
Old Dec 12, 2007 | 07:22 AM
Roeri's Avatar
Roeri
UPDATE
I noticed last night that the sound goes away when the clutch is engaged. Could this be the flywheel?
It either goes completely away or minimizes significantly....
Old Dec 12, 2007 | 08:23 AM
miminut's Avatar
miminut
From: Half Moon Bay California, 25 miles south of SF on the coast
Throwout bearing
Is noise pronounced when you push in the clutch? Does it attenuate when the cluch is engaged? That sounds like a throwout bearing going out.
Old Dec 12, 2007 | 08:42 AM
Roeri's Avatar
Roeri
The noise is present when in neutral and not on the clutch like when sitting at a stop light. If I press the clutch the noise stops.
Honestly it sounds like a bunch of rocks tumbling about in my engine area. But this is from the drivers seat, I haven't been able to pinpoint the location yet.
Old Dec 12, 2007 | 09:28 AM
kenchan's Avatar
kenchan
+1 on the throwout bearing.
Old Dec 12, 2007 | 09:30 AM
Roeri's Avatar
Roeri
This something that is usually covered by warranty?
Old Dec 12, 2007 | 11:55 AM
Big-Daddy-Blue's Avatar
Big-Daddy-Blue
are you running an aftermarket short shifter?
I had one installed on my last car and it had the same symptom you are experiencing. I could hear the throw out bearing slot more
Old Dec 12, 2007 | 12:04 PM
Roeri's Avatar
Roeri
Stock
Old Dec 12, 2007 | 02:45 PM
roadodendron's Avatar
roadodendron
I had a noise similar to this. Rotating/grinding noise with the clutch out and diminished when pressed in. The noise was also there when in 1st or 2nd and about 2800rpm. It turned out to be the input shaft bearing in the transmission. Unfortunately, the parts to repair it are not available.
Old Dec 12, 2007 | 02:48 PM
Sissy's Avatar
Sissy
My 2006 does the same thing. I'm about to schedule her 10,000 oil change/check up. Will inquire.
Old Dec 12, 2007 | 03:15 PM
Roeri's Avatar
Roeri
Not available? So then what happens? They just say they can't fix it? Or they replace the entire transmission?
This is getting scary...
Old Dec 12, 2007 | 07:38 PM
ozarkroots's Avatar
ozarkroots
Coordinator :: Mini's of the Ozark Region
gringing noise in neutral
If the car is in neutral and the clutch is out ( left foot on floor) and there is a grinding noise it is NOT the throwout bearing because the throwout bearing is only in use if the clutch is depressed. If the noise goes away when the clutch is depressed then the noise is ( I am sorry to say ) in the transmission.
Another way to understand this is that when the clutch is depressed, the engine is disconnected from the transmission and the transmission input shaft is at rest; clutch out and the input shaft is turning ( and its bearing).
We will all pray for you now.
Old Dec 12, 2007 | 07:56 PM
resmini's Avatar
resmini
Have you changed the transmission fluid? If it's broke this isn't going to fix it...still, for 15 bucks or so I'd change the fluid and see if that helps. Of course, if you're still under warranty, just take it in and get them to fix it.
Old Dec 12, 2007 | 08:12 PM
Ancient Mariner's Avatar
Ancient Mariner
Had a similar noise in my '02. Result: replaced tranny- under warrenty thank goodness.
Old Dec 13, 2007 | 06:16 AM
Roeri's Avatar
Roeri
Yeah, the sound is present only when the clutch is NOT engaged. Again, sounds like a bunch of rocks are tumbling about in my engine.
Old Dec 13, 2007 | 06:31 AM
skillet's Avatar
skillet
+1. My MINI has done this from day 1 when I bought it. My old Jetta also had this issue. I believe it's flywheel chatter. When I upgraded to a light weight flywheel in my Jetta, it only got worse. Don't be alarmed.
I'm currently at 101,000 miles, and like I said, no problems yet. You just have to live with it (like the annoying rattles and what not )
Old Dec 13, 2007 | 11:07 AM
Roeri's Avatar
Roeri
This goes beyone an annoying "rattle" though. It wasn't there before about a month ago and is progressivley getting worse. The sound makes my car sound like a piece of s**t, which it is not. It's almost embarrasing to be at a red light.
I am praying that I don't get the "thats normal" reason from DTM.
Old Dec 13, 2007 | 11:17 AM
skillet's Avatar
skillet
If you turn your AC on, does it get louder? Mine goes and comes as it wants, so it wouldn't surprise me if you're having the same issue.
Old Dec 18, 2007 | 11:08 AM
Roeri's Avatar
Roeri
UPDATE!!!!
Had my car at DTM yesterday and the problem is....
Wait for it.....
The flywheel and some kind of "plate." (forgot what he said)
Both are being replaced under warranty.
YAY!!!
Old Dec 18, 2007 | 11:11 AM
Eric_Rowland's Avatar
Eric_Rowland
'pressure plate' - it's what presses the clutch up against the flywheel.
Nice to know you get it under warranty.
Colt45Magnus
Aug 27, 2024 05:03 AM
Sc00terbum
Sep 11, 2015 07:17 AM
Sep 8, 2015 11:37 AM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 3, 2015 03:01 PM
